Shared coordinates
Shared coordinates
Antipin_m
Shared coordinates
Antipin_m
Hello!
Can u please explain me how to compare shared coordinates between files and make sure that it is the same?
Mohamed_Arshad
HI @Antipin_m
     Kindly follow the below steps to compare shared coordinates between two files.
01. Open the both project documents.
            UIDocument UIDoc = app.OpenAndActivateDocument(@"C:\DocStorage\Demo5.rvt");
02. Get Coordinates and compare.
  UIDocument uiDoc_01 = app.OpenAndActivateDocument(@"C:\DocStorage\Demo5.rvt");
            Autodesk.Revit.DB.Document doc_01 = uiDoc_01.Document;
            BasePoint basePoint01 = new FilteredElementCollector(doc_01)
                .OfCategory(BuiltInCategory.OST_SharedBasePoint)
                .First() as BasePoint;
            UIDocument uiDoc_02 = app.OpenAndActivateDocument(@"C:\DocStorage\Demo6.rvt");
            Autodesk.Revit.DB.Document doc_02 = uiDoc_02.Document;
            BasePoint basePoint02 = new FilteredElementCollector(doc_02)
            //Get First Project Basepoint
            XYZ position01 = basePoint01.SharedPosition;
            //Get Second Project Basepint
            XYZ position02 = basePoint02.SharedPosition;
            //Compare the
            if ((position01.X.Equals(position02.X) && position01.Y.Equals(position02.Y) &&
                (position01.Z.Equals(position02.Z))))
                TaskDialog.Show("Information", "Shared Coordinates of two projects are same");
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
Antipin_m
@Mohamed_Arshad. Hi!
Thank u so much.
But this method compares shared coordinates of the BasePoints, which can be different in files, which have shared coordinates.
Mohamed_Arshad
Hi @Antipin_m
can please showcase with an example image that which you need to compare exactly with other projects
Mohamed Arshad K
