Setting up Survey Point programtically
Hello Everyone,
I want to perform a seemingly trivial task. I am trying to setting-up positional values (NS EW Elev) of a Survey point, programtically.
One of the articles on this topic says its not possible via API. However the article is almost three years now, so i hope API has got richer in this area.
if(basePoint.IsShared)
                  basePoint.Pinned = false;
                  basePoint.get_Parameter(BuiltInParameter.BASEPOINT_NORTHSOUTH_PARAM).Set(100);
This code throws exception: "There parameter is read-only".
Is there a better / another way of doing it in Revit API 2016?
Thanks in advance.
Best regards,
Kinjal.
Finally figured-it-out. It can be achieved uidoc.Document.ActiveProjectLocation.
Following is code to set value of Survey point programtically (that is values for NS, EW, Elev):
//1: Set Survey point values
ProjectLocation projectLocation = uidoc.Document.ActiveProjectLocation;
ProjectPosition projectPosition = projectLocation.get_ProjectPosition(origin);
projectPosition.NorthSouth = <double value>;
projectPosition.EastWest = <double value>;
projectPosition.Elevation = <double value>;;
projectLocation.set_ProjectPosition(origin, projectPosition);
//2: Move survey point wrt Project base coordinate
var locations = collector.OfClass(typeof(BasePoint)).ToElements();
foreach (var locationPoint in locations)
        BasePoint basePoint = locationPoint as BasePoint;
        if (basePoint.IsShared)
basePoint.Pinned = false; basePoint.Location.Move(new XYZ(0, 1, 0)); } }
One issue remains. If survey point is relocated (see step 2 in code above) to Origin instead of a non-origin (0,1,0 in this case), the Survey point doesn't move to origin and appears at negative relational position from Project Base point. But thats separate issue so i will make it to a separate question. Thanks everyone.
Kinjal.
