Setting Material Parameter Not Working
I have a C# Command that is creating Materials in Revit. You can see in the image below I'm successfully creating a new material and setting all the Physical Parameters in yellow without issue. However, I'm having issues setting the "Tension Parallel to Grain" Parameter.
I'm getting that Parameter using the BuiltInParameter.PHY_MATERIAL_PARAM_SHEAR_PERPENDICULAR. When I attempt to ".Set(500);" the Parameter, it is returning false. I noticed that the UserModifiable attribute of the Parameter is "false". So I have two questions:
1) Is it possible to set a Parameter that is marked as UserModifiable:false? I noticed in the API docs, it mentions this Parameter can't be modified by the UI, but I am able to Modify it using the UI. Do I have the wrong Parameter? (The Parameter name matches the "Tension Parallel to Grain" name).
2) How do I set the "Tension Parallel to Grain" Parameter?
