SetCategoryHidden is not working as desired in Revit 2018
We had a Revit API which is used to Set the Visibility Toggled based on our requirements. It was working fine until Revit 2017.
With Revit 2018, the SetCategoryHidden is not working.
The error says Category cannot be hidden.
Snippet
Category category = document.Settings.Categories.get_Item(BuiltInCategory.OST_Grids);
document.ActiveView.SetCategoryHidden(category.Id, true);
Revitalizer
the view you use may not be the one you expect:
https://forums.autodesk.com/t5/revit-api-forum/uidocument-activegraphicalview-and-uidocument-activev...
Also, may it be that the Grid visibility cannot be set in that view because of dependencies (Template, Filter) ?
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Yeah, understand. Thank you.
