Set View template to None
mliuAP3CU
mliuAP3CU
Looking to click a button and set the view template for all views in project to none.
Button works but code to remove view templates does not.
I ran into the following problem (see screenshot). Not sure how to fix it
Any help appreciated. Thank you
Mohamed_Arshad
HI @mliuAP3CU
    In Revit API we have two ways to Set View Template ID.
///1. Using Direct Property of View
 v.ViewTemplateId = ElementId.InvalidElementId;
///2. Using its Parameter
v.get_Parameter(BuiltInParameter.VIEW_TEMPLATE).Set(ElementId.InvalidElementId);
Reference Code
            using (Transaction viewTemplate=new Transaction(doc,"Set to None"))
                viewTemplate.Start();
                if (!v.IsTemplate)
                    ///Or you can use the below parameter
                    //v.get_Parameter(BuiltInParameter.VIEW_TEMPLATE).Set(ElementId.InvalidElementId);
                viewTemplate.Commit();
Error Definition
    In you code you have used GetParameters Method this method will return IList<Parameter> [List of Parameters having same name]. But in our case to avoid confusion you can directly use the ViewTemplateId Property. Don't prefer Parameter.
Hope this will helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
