Set string value to a parameter
Or.levi
Or.levi
hey,
im trying to change a parameter's string value to a new one by using the user input.
however, it seems like it won't change when i'm using the .setStringValue method.
( it does change when i manually insert new text to the parameter input)
any idea what can i do?
thanks!
// user input for finding the circuit string, and a new value to replace it
            string find_txt = Microsoft.VisualBasic.Interaction.InputBox("Please insert the text you want to find", "find", "");
            string replace_txt = Microsoft.VisualBasic.Interaction.InputBox("Please insert the text you want to REPLACE", "REPLACE", "");
            IEnumerable<Element> familyInstanceCollector = new FilteredElementCollector(doc)
                .OfClass(typeof(FamilyInstance)).WhereElementIsNotElementType().ToElements();// get a collection of tags
            foreach(Element element in familyInstanceCollector)
                if (element.Name == "circuit name")// looking for a specific electical fixture
                    foreach (Parameter parameter in element.Parameters)
                        if (parameter.HasValue)
                            if(parameter.AsValueString().Contains(find_txt))
                                parameter.SetValueString(replace_txt);
                                TaskDialog.Show("show parameter value", parameter.AsValueString());// should show the new given input value
                        //TaskDialog.Show("shwo parameter name", parameter.Definition.Name);
RPTHOMAS108
SetValueString is for value types e.g. LengthParam.SetValueString("1'2""")
For setting strings use Parameter.Set.
Likewise for getting the string value use Parameter.AsString not Parameter.AsValueString
minet.axel
Can it be used with family type parameters (ElementId)?
