Set Solid In view Structural Rebar
jamess166
jamess166
Good day,
I need to apply the SetSolidInView method for all the Structural Rebar in active 3d view, I hope suggestion. Thanks in advance.
HI jamess,
ICollection<Element> rebers = new FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_Rebar).ToElements();
                List<Rebar> List_Rebar = new List<Rebar>();
                if(rebers==null)
                    TaskDialog.Show("REBAR", "NO REBAR EXISTS IN THE DRAWINGS");
                Transaction trans = new Transaction(doc);
                trans.Start("ACTRAN");
                IEnumerable<ViewFamilyType> VFT = from Element in new FilteredElementCollector(doc).OfClass(typeof(ViewFamilyType)) let type = Element as ViewFamilyType where type.ViewFamily == ViewFamily.ThreeDimensional select type;
                View3D v3d = View3D.CreatePerspective(doc, VFT.First().Id);
               foreach(Rebar r in rebers)
                    r.SetSolidInView(v3d, true);
                    List_Rebar.Add(r);
                TaskDialog.Show("LIST_REBAR", List_Rebar.Count().ToString());
                trans.Commit();
jamess166
Thank you very much for your help, I have modified my code according to your recommendation, but two things happen:
- I do not detect any structural Rebar.
- Create a new 3D view and do not use the current view I have.
Hi @jamess166,
From your screenshot it shows that the condition is set to (rebar !=null).
could you please change this condition to (rebar= =null).
jamess166
If it really works for me, but there is some way to execute the solid rebar in view method without having to create a new 3d view, and apply it to the 3d active view.
jamess166
I still can not find the solution
so-chong
Try to replace this line of code:
with this line of code:
View3D v3d = doc.ActiveView as View3D;
Also try to reuse the 'using' statement in your code.
Your first screenshot shows that you were using it.
Hope this helps!
