Set SetElementOverrides inside an IUpdater
atir5UTNF
atir5UTNF
Is it possible to set SetElementOverrides (e.g., change color etc..) inside an updater?
For some reason this line causes my updater to fail.
If I skip this line, it works.
Thanks.
ricaun
I suppose is possible, never tried.
What error/exception happens in the updater when you use SetElementOverrides? And a sample code with your update Execute(UpdaterData data) method would help.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
atir5UTNF
Yes, it turns out it's possible.
I tried writing a simple example to send you, and it worked there.
The issue on my actual updater was that the elements I was trying to override were created inside the updater, so I had to call  regenerate() before making changes.
Thanks.
