Set Reference Plane on Reference Line Problem
Hi, I am creating family in code. For that I am using family document created from template - Metric Generic Model. That document has only one reference line which I created previously by hand. In code I want to do selection of Work Plane, same as can be done by hand in Revit using option Pick a plane. Plane witch I target is one of Reference Plane at Reference Line. Do someone have idea how to accomplish it?
rosalesduquej
Ok I'm trying to understand what you are doing. Let's start from the beginning. You are creating a new Family document from the API based on a Template. using which method? are you using  application.NewFamilyDocument(templateFileName);
Ok let's assume you are. What you can do after is modify that family, have you tried that? There is a method called EditFamily in the Document class which will get you the document of a loaded family to edit. After that you could reload your family to the Document with the LoadFamily method.
Have you used this before?
In case not, I'm sharing a very useful link about Families in Revit API. http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-DC143EB8-43CB-48AB-938E-7ADE3A9D2E63
Once that part is cleared out you can continue with the set of Reference Plane.
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Thank you Jaime,
I have found Reference Plane by filtering Sketch Planes in my Family Document and chose appropriate one by its name.
FilteredElementCollector collectorSP = new FilteredElementCollector(familyDocument).OfClass(typeof(SketchPlane));
SketchPlane skethPlane = null;
foreach (SketchPlane sp in collectorSP)
if (sp.Name == "Reference Lines")
skethPlane = sp;
break;
if (skethPlane == null) return;
Now I have another problem - I want to place new family instance on that plane. To explain, I am now creating family witch has inside another family, so I want to insert that “second’ family in working one, let’s call working family MainFamily and second SecondFamily. For that, I have used method NewFamilyInstance with next parameters:
NewFamilyInstance(Reference reference, XYZ location, XYZ referenceDirection, FamilySymbol symbol);
  • reference: skethPlane.GetPlaneReference() – reference from filtered skethPlane.
  • location:GeometryCurve.GetEndPoint(0) – start point of reference line in MainFamily (working family)
  • referenceDirection: GeometryCurve.GetEndPoint(1) - referenceLine.GeometryCurve.GetEndPoint(0) – direction of line
  • symbol: symbol of SecondFamily
In SecondFamily I set parameter FAMILY_WORK_PLANE_BASED to true. familyDocument.OwnerFamily.get_Parameter(BuiltInParameter.FAMILY_WORK_PLANE_BASED).Set(1);
All that together looks like this:
FamilyInstance instance = familyDocument.FamilyCreate.NewFamilyInstance(skethPlane.GetPlaneReference(), referenceLine.GeometryCurve.GetEndPoint(0),
referenceLine.GeometryCurve.GetEndPoint(1) - referenceLine.GeometryCurve.GetEndPoint(0), profileSymbol);
But, it have not worked when I moved reference line I got warning or there is not connection between instance and reference plane from reference line. Do you have an idea what to do? Again, I want to place my SecondFamily on WorkPlane picked on ReferenceLine from MainFamily…
