Set Normal to create rebar
Message 1 of 9
Hi! I'm using the function Rebar, but I have problems when my lines aren't liying in the normal 1,0,0 : 0,1,0 and 0,0,1
How to get the normal from this set of coordinates:
23.73542   0.65550   2.67900
23.73542   0.65550   2.15279
23.65644   1.55819   1.55100    ---PA
23.25398   6.15835   1.55100    ---PB
23.17501   7.06104   2.15279
23.17501   7.06104   2.67900
I guess that I must be use PA - PB for it but it doesn't work..
Any idea about it?
Thanks in advance.
Luis.
Replies (8)
Message 2 of 9
jeremytammik
Dear Louis,
I suggest that you search the Revit SDK samples globally for the NewRebar function calls and see how they handle it there.
Have you done that yet?
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 9
Hi Jeremy! ... I'm followong that and my problem is to get the vector (normal)....
 rebar = Rebar.CreateFromCurves(doc, RebarStyle.Standard, RT, null, null, el, setHook.SetNormal, GetCurves(item), RebarHookOrientation.Right, RebarHookOrientation.Right, true, true);
and It's working when the coordinates set to the plane:
BasisX
BasisY
BasisZ
but when it'not doesn't work!
Thanks to answer!
Luis.
Message 4 of 9
Mustafa.Salaheldin
What is "setHook.SetNormal"? and What are you exactly want to do?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Message 5 of 9
Hi!
setHook.SetNormal is a class that I've créate to evaluate the normal from a set of coordinates..... and another functions.
my function evaluate y the coordinates have a common axis, and return a xyz normal.... I've already created rebars when all coordinates were liying on an axis for example:
set of coordinates 1: the normal is new XYZ(0, 1, 0);
3.92706 1.92077 -0.76725
3.92706 1.92077 -0.04750
0.24606 1.92077 -0.04750
0.24606 1.92077 -0.76725
set of coordinates 2: the normal is new XYZ(1, 0, 0);
3.74456 0.01327 -0.76930
3.74456 0.01327 -0.07000
3.74456 7.70327 -0.07000
3.74456 7.70327 -0.76930
set of coordinates 3: the normal is new XYZ(0, 0, 1);
3.56151 -0.00073 -0.20350
3.94556 -0.00073 -0.20350
3.94556 7.71727 -0.20350
3.56151 7.71727 -0.20350
and so far so good.... I was creating rebars without problema in the element in Revit
here is the hardest part
-16.28757 7.02486 1.89219
-16.29806 7.08438 1.93684
-16.29806 7.08438 3.31943
-16.27909 6.97681 3.42700
-16.26392 6.89074 3.42700
How to get the normal?
and about your question! a rebar
Thanks!
Luis!
Message 6 of 9
Mustafa.Salaheldin
Do you calculate the Normal vector from a Surface, Line or manually? Please provide your code and Revit sample project so I may can help.
¯\_(ツ)_/¯
Mustafa Salaheldin
Message 7 of 9
About Normal, i set for all case as:
normal = new XYZ(1, (-(x2 - x1) / (y2 - y1)), 0);
Message 8 of 9
FAIR59
You need 3 points to define a plane (and a normal)
Given 3 distinct points a,b, and c, you can find the normal as the crossproduct between b-a and c-a.
XYZ normal = b.Subtract(a).CrossProduct(c.Subtract(a));
Message 9 of 9
My Plane set by cordinate
Examble for rebar Beam
P1: the first Beam (x1,y1,z1)
P2: the end beam (x2,y2,z2)
I set P3 in plane Oxy => P3 (x1,y1,0) or (x2,y2,0)
=> my plane (P1,P2,P3)
=> Normar as above for all case
=> Similar column
