Set Materials on CompoundStructureLayer
Message 1 of 8
Hi
I want to change the material on all the layers of Walls and Floors to the same material
I get the MaterialId, loop through all the Layers, make a new layer with the same thicknes and function but with the new material and then set the layer to match the new layer, but... it doesn't work
What do I do wrong ??
My code look like this:
public void ChangeMaterialonLayers(CompoundStructure LC_CS, ElementId MatId)
    IList<CompoundStructureLayer> cslayers = LC_CS.GetLayers();
    int LayerIndex = 0;
    foreach (CompoundStructureLayer csl in cslayers)
       CompoundStructureLayer TempLayer = new CompoundStructureLayer(csl.Width, csl.Function, MatId);
       LC_CS.SetLayer(LayerIndex, TempLayer);
       LayerIndex++;
Regards Anders
Replies (7)
Message 2 of 8
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
After setting the Compound structure with the compound structure layers ,Set the compound structure to the wall type or floor type.
 wall.WallType.SetCompoundStructure( compound structure );
I think the below link will help you
https://thebuildingcoder.typepad.com/blog/2011/03/many-issues-resolved.html#1264438
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
Hi
Thanks, that works :-), on Floors and ceilings
but, on the walls I got an exception: "This operation is valid only for non-vertical compound structures...."
What is different for Walls ?
Message 4 of 8
jeremytammik
Have you tested to ensure that what you are trying to achieve programmatically works manually through the user interface at all?
Jeremy Tammik
The Building Coder
Message 5 of 8
Yes 🙂
Manually it is the same process to change materials on the layers on Floors and Walls and the same code works fine on ceilings and Floors, but not on walls. and the exception is specific about non-vertically compound, and that must be the walls, or ?? 🙂
But I don't see the differents
Regards
Anders
Message 6 of 8
FAIR59
maybe it has to do with the layerId , which maybe different from the index in the array.
LC_CS.SetLayer(csl.LayerId, TempLayer);
Message 7 of 8
If I look at a Floor and a Wall via RevitLookup, the Layers have the same LayerID, starting from 0
and if I change the code to only change the material on the First Layer [0], it will do it on the Floors but still not on the Walls  !!
Message 8 of 8
FAIR59
I don't know why the Exception gets thrown for walls and not for floors.
There are 2 methoeds that work:
  1. Use  SetMaterialId()
    foreach( CompoundStructureLayer l in structure.GetLayers())
    	structure.SetMaterialId(l.LayerId, mat.Id);
    walltype.SetCompoundStructure(structure);
  2. Make a List of newLayers
    List<CompoundStructureLayer> layers = new List<CompoundStructureLayer>();
    	CompoundStructureLayer newLayer = new CompoundStructureLayer(l.Width,l.Function,mat.Id);
            layers.Add(newLayer);
    structure.SetLayers(layers);
