Set Formula in Family
Hello All!
I was browsing around the api documentation and found a SetFormula method but am not quite sure how it used. I am wanting to set the formula for a specific family. But my searches on the forum and elsewhere of google have not yielded many results unless I am not understanding something. How would I get a specific family in a project, then set the formula on the family?
Something like MyTestFamily.SetFormula mytestFormulaField myformula
Thanks in advance all!
Hello Samuel,
Well, first I think you need to actually use that on a Family document type. See this link:
http://thebuildingcoder.typepad.com/blog/2009/11/family-parameter-value.html
And then you could use that formula in the family you want
http://www.revitapidocs.com/2015/cdc3156c-0334-0bba-70af-1df78fb18b50.htm
Cheers
Ok, I am beginning to understand now. Is there anyway to specifically load a family via the API? like search for it in the project. Something like
Family myFamily = new MyTestFamily()
From what I am understanding, the method you linked (which was a great resource I am going to use that for sure) only works via user input and when they are currently looking at the document. Is there anyway I can automate that process?
Thank you for the reply! Im fairly proficient in programming, but still learning the ropes of Revit.
Hello Samuel,
In order to automatize, perhaps try using the
FilteredElementCollector families
      = new FilteredElementCollector( doc )
        .OfClass( typeof( Family ) );
To get all families in the project, and then use a foreach loop
foreach( Family f in families )
// do your thing
Inside the foreach, you select the family you want to work on, or work on all of them. By the way, all this info is in this link:
http://thebuildingcoder.typepad.com/blog/2014/09/modifying-saving-and-reloading-families.html
Cheers
Ruben
Awesome Thank you! I will look into implementing that. I appreciate all the help 😄 I will also take another look at that link for things that I most likely (and obviously) missed.
Thanks!
