set BytesIO() instead of Path when export image
dyakovenko73GY8
dyakovenko73GY8
Hey there everyone!
Is there a possible way to export image from viewport using the next pipeline
opts = DB.ImageExportOptions()
opts.FilePath = image_path
doc.ExportImage(opts)
 using BytesIO() object instead of string-type image path? I am trying to perform image post-process right inside the python script without having to write the file and re-opening it again.
Thanks in advance!
jeremy_tammik
Not as far as I know. Sorry about that. You can file a wish list item for it in the Revit Idea Station if it is very important for you.
