Set area load orientation to project ... How?
Sydra7
Sydra7
Hi guys!
I have a big problem about area loads. I want to create new loads with my addin but every created area load is oriented the workplane. How can i change that? Is there an analog api function like "Orient to" option in the gui? (I don't find the solution since three days :()
Regards
David
gopinath.taget
Are you able to change the orientation using the UI. Typically, if you are not able to change it using the UI, you cannot change it using the API (sorry for the bad news).
Best Regards,
Gopinath
andrzej.trelinski
Hi Sydra7,
It is possible to change "Orient To" parameter through API in Revit 2014RTM.
I have attached "ChangingLineLoadOrientToViaAPI.rvt" file, with working solution for You:
1. Load    attached "ChangingLineLoadOrientToViaAPI.rvt" file. (File saved in 2014 RTM)
2. Choose "Enable Macros" on start up
3. Select LineLoad in 3D view
4. Run Manage tab -> Macro Manager -> Project tab
5. Expand "Loads" and select "ChangingLineLoadOrientToViaAPI" C# macro
6. Click run.
7. Popup should show and OrinetTo parameter for LineLoad should change
C# code from inside is:
        public void ChangingLineLoadOrientToViaAPI()
            FilteredElementCollector collector = new FilteredElementCollector(this.Document);
            IList<Element> elements = collector.WherePasses(new ElementCategoryFilter(BuiltInCategory.OST_LineLoads)).WhereElementIsNotElementType().ToElements();
            using (Transaction transaction = new Transaction(this.Document))
                transaction.Start("ChangingLineLoadOrientToViaAPI");
                foreach (LineLoad load in elements)
                    Parameter param = load.get_Parameter(BuiltInParameter.LOAD_USE_LOCAL_COORDINATE_SYSTEM);
                    int orgVal = param.AsInteger();
                    int newVal = (orgVal == 0) ? 2 : 0;
                    param.Set(newVal);
                    TaskDialog.Show("ChangingLineLoadOrientToViaAPI""LineLoad ID: " + load.Id + "; Original OrientTo value was: " + orgVal + "; New OrientTo value: " + newVal);
                TransactionStatus ts = transaction.Commit();
Andrzej Trelinski
andrzej.trelinski
Hi Sydra7,
Since Revit 2015RTM, "Orient to" parameter for Point, Line and Area loads can be get and set directly by parameter OrientTo in LoadBase class (which is base class for PointLoad, LineLoad and AreaLoad classes).
Ex: pointLoad.OrientTo = enum { Project, WorkPlane, HostLocalCoordinateSystem }
Best regards,
Andrzej Trelinski
Revit developer
