Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Set a value for Shared parameter
2 REPLIES 2
antonFFF2V
287 Views, 2 Replies
antonFFF2V
Hello everyone. I don't have much experience with Revit API, so I confused with parameters.
In our project we have shared parameter (type - Length) for structural framing which we use to get absolute elevation in Tags.
This parameter also is a parameter of type in family of structural framing.
I wanted to set the value of this shared parameter in type with LookUp, but I've understood that it doesn't work.
Please help or give advice, how can I get and set shared parameter of type?
Labels (2)
2 REPLIES 2
antoine_ferron
in reply to: antonFFF2V
antoine_ferron
You have to retrieve the FamilySymbol of your familyInstance to get and set a parameter of type look at the code below :
 FamilySymbol familySymbol = familyInstance.Symbol;  //familyInstance is one instance of your Structural Framing
            using (Transaction ts = new Transaction(doc, "Change value of parameter"))
                ts.Start();
                familySymbol.LookupParameter("NameOfYourParameter").Set(TheNewValue);
                ts.Commit();
                ts.Start();
                ts.Commit();
antonFFF2V
in reply to: antoine_ferron
antonFFF2V
Thank you, your idea and code helped me
