Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Select Floor Slabs and Height Difference between them to place formwork family
3 REPLIES 3
d.ahmed.hb
1098 Views, 3 Replies
im a little new to C#, I was trying to look for a way where the Plug-In lets me select a top floor slab and then the bottom floor slab, so that I can subtract the parameters from both and get the height difference. The issue is I do not understand how to tell the code to let me select the second floor slab. Is there a link which describes something similar?
I have been successful in selecting the first floor slab and display the height of its bottom surface. To calculate the height difference I need to be able to select the bottom floor slab and get its top height, then I can subtract the two. But this seems to be a challenge. Any similar link or code, which does this?
Labels (7)
3 REPLIES 3
naveen.kumar.t
in reply to: d.ahmed.hb
Hi @d.ahmed.hb ,
Are you looking for this?
 //Lets you to Select first floor
                Reference r1 = uidoc.Selection.PickObject(ObjectType.Element);
                Floor firstFloor = doc.GetElement(r1.ElementId) as Floor;
                Parameter firstFloorParameter = firstFloor.get_Parameter() (or) firstFloor.LookupParameter("");
                double firstFloorHeight = firstFloorParameter.AsDouble();
//Lets you to Select second floor
                Reference r2 = uidoc.Selection.PickObject(ObjectType.Element);
                Floor secondFloor = doc.GetElement(r2.ElementId) as Floor;
                Parameter secondFloorParameter = secondFloor.get_Parameter() (or) secondFloor.LookupParameter("");
                double secondFloorHeight = secondFloorParameter.AsDouble();
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
d.ahmed.hb
in reply to: naveen.kumar.t
Hey @naveen.kumar.t, thanks a ton. It worked like a charm. Helped me out big time 🙂
alaraJ3LSY
Gentlemen,
Does this work with sloping floors (top or bottom or both)?
