Select element in PickObject (or make the selected element graphically visible)
jens.slofstra!
jens.slofstra!
Hi everyone,
I am making a selection tool but ran into a problem with visually indicating the selected element.
If possible I would like to avoid using PickObjects.
The current code follows these steps:
- PickObject in a while loop
- After PickObject I would like to select the element but PickObject clears this selection.
- New solution override element graphics but this doesn't quite work (I don't know why).
Below you will find the code I currently have:
private Document _doc;
private UIDocument _uidoc;
using(var subtx = new SubTransaction(_doc))
                    subtx.Start();
                    var overrideHighlight = new OverrideGraphicSettings();
                    overrideHighlight.SetProjectionLineColor(new Color(0, 0, 255));
                    var overrideClear = new OverrideGraphicSettings();
                    var elementList = new List<ElementId>();
                    var exitSelection = false;
                    while (!exitSelection)
                        try
                            var element = _doc.GetElement(
                                                _uidoc.Selection.PickObject(
                                                    Autodesk.Revit.UI.Selection.ObjectType.Element,
                                                    new SelectionFilterByFamily("FamilyName")));
                            if (!elementList.Contains(element.Id))
                                elementList.Add(element.Id);
                                _doc.ActiveView.SetElementOverrides(element.Id, overrideHighlight);
                                _doc.Regenerate();
                            else
                                elementList.Remove(element.Id);
                                _doc.ActiveView.SetElementOverrides(element.Id, overrideClear);
                                _doc.Regenerate();
                        catch (Autodesk.Revit.Exceptions.OperationCanceledException)
                            exitSelection = true;
                    subtx.Commit();
If possible I would like one of two solutions:
- Have the PickObject method not clear the selection.
- Override graphics but display them properly.
miguelmachadoecosta
Doesn't reselecting the elements solve your problem? Adding the following line after the if statement:
_uidoc.Selection.SetElementIds(elementList);
jens.slofstra!
@miguelmachadoecosta,
No, this is sadly not possible. Because when I call the next pickobject methode the selection will be cleared.
miguelmachadoecosta
It seems that in order to retain the selection you have to use this method, which might make you want to ditch the loop: https://www.revitapidocs.com/2022/eac2b67c-28ae-f057-501e-bff28ea4dcfe.htm
Try this:
List<ElementId> elementList = _uidoc.Selection.GetElementIds();
List<Reference> referenceList = elementList.Select(x => new Reference(_doc.GetElement(x))).ToList;
try
    referenceList = _uidoc.Selection.PickObjects(Selection.ObjectType.Element, new SelectionFilter(), "Select any elements", referenceList);
    elementList = referenceList.Select(x => x.ElementId).ToList;
catch  Autodesk.Revit.Exceptions.OperationCanceledException)
With this selection filter, for example:
public class SelectionFilter : Selection.ISelectionFilter
    public bool AllowElement(Element element)
        return true;
    public bool AllowReference(Reference refer, XYZ point)
        return false;
P.S.- I converted this code from VB.NET to C#, so not sure if the syntax is 100% correct.
