Select element faces using a Form
Hi All,
I'm trying to achieve the selection of element faces using a custom form. The procedure is as follows:
1.- When the user starts the script, the form pops up with different buttons to select different things.
2.- In this selection of elements and parameter, the user sets up the info that the code will use to perform certain tasks.
3.- When the user hits "OK" button, the code starts to make the operations and after some time it gets the result.
Simple as that.
The issue is this. When I start the code, the form pops up but when I press the button to select the element faces the form stays on the screen and is blocking the user to pick these objects.
This es my Command.cs:
#region Namespaces
using System;
using System.Collections.Generic;
using System.Diagnostics;
using dBox = System.Windows.Forms;
using System.Windows.Forms;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
#endregion
namespace BarraHorPAPA
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Autodesk.Revit.ApplicationServices.Application app = uiapp.Application;
            Document doc = uidoc.Document;
            frmHorPAPA f = new frmHorPAPA(uiapp);
            try
                if (f.ShowDialog() == DialogResult.OK)
                    //Llama al formulario para la obtención de datos.
                    List<ElementId> ids = f.getCaras();
                    List<Element> lstCaras = new List<Element>();
                    using (Transaction tx = new Transaction(doc))
                        tx.Start("Seleccionar Caras.");
                        foreach (ElementId eid in ids)
                            Element ele = doc.GetElement(eid);
                            lstCaras.Add(ele);
                        tx.Commit();
                        TaskDialog.Show("test", lstCaras.Count.ToString());
            catch (Exception ex)
                TaskDialog.Show(" Info ", ex.GetType().Name + " " + ex.Message);
            return Result.Succeeded;
and this is my form:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
    public partial class frmHorPAPA : System.Windows.Forms.Form
        List<ElementId> lstCaras;
        UIApplication uiapp;
        UIDocument uidoc;
        Autodesk.Revit.ApplicationServices.Application app;
        Document doc;
        // se trae UIApplication desde el Command - que posee CommandData.
        public frmHorPAPA(UIApplication uiApp)
            InitializeComponent();
            uiapp = uiApp;
            uidoc = uiApp.ActiveUIDocument;
        private void frmHorPAPA_Load(object sender, EventArgs e)
            lstCaras = null;
        private void btnCaras_Click(object sender, EventArgs e)
            IList<Reference> caras = uidoc.Selection.PickObjects(ObjectType.Face, "Selecciona las caras de los limites");
            List<ElementId> ids = (from Reference r in caras select r.ElementId).ToList();
                lstCaras.Add(eid);
        #region MÉTODOS PARA EL ENVIO DE VARIABLES AL COMMAND
        public List<ElementId> getCaras()
            return lstCaras;
        #endregion
        private void btnOK_Click(object sender, EventArgs e)
What would you recommend to do in this case, to achieve what I'm trying to do?
Thanks in advance!
BardiaJahan
You are using a modal form. The command shows the form in a modal way waiting for the form to report back DialogResult.Ok and your form does not do that upon clicking on that button. In this case, I would use a modeless form. See:
http://thebuildingcoder.typepad.com/blog/2011/09/modeless-forms-in-revit.html
Thanks @BardiaJahan! I'll follow your directions.
Cheers!
