Script doesn't work after use "Revit Release" configuration
jw.vanasselt
jw.vanasselt
Hi all,
I running into a strange problem.
We have a solution and we have set configuration settings in it.
I used this video made by @ricaun
Update your RevitAddin project to work with Multiple Revit Version - YouTube
<?xml version="1.0" encoding="utf-8"?>
<Project Sdk="Microsoft.NET.Sdk">
	<!-- Projectinformatie -->
	<PropertyGroup>
		<ResolveAssemblyWarnOrErrorOnTargetArchitectureMismatch>None</ResolveAssemblyWarnOrErrorOnTargetArchitectureMismatch>
		<AppendTargetFrameworkToOutputPath>false</AppendTargetFrameworkToOutputPath>
		<OutputType>Library</OutputType>
		<ProjectGuid>{CC4ED8F9-47BC-4AAC-AB22-93E9CD7735C3}</ProjectGuid>
		<Configurations>Debug 2020;Debug 2021;Debug 2022;Debug 2023;Debug 2024;Revit Release</Configurations>
	</PropertyGroup>
	<!-- Revit versie -->
	<Choose>
		<When Condition="$(Configuration.Contains('2020'))">
			<PropertyGroup>
				<RevitVersion>2020</RevitVersion>
				<TargetFramework>net48</TargetFramework>
			</PropertyGroup>
		</When>
		<When Condition="$(Configuration.Contains('2021'))">
			<PropertyGroup>
				<RevitVersion>2021</RevitVersion>
			</PropertyGroup>
		</When>
		<When Condition="$(Configuration.Contains('2022'))">
			<PropertyGroup>
				<RevitVersion>2022</RevitVersion>
			</PropertyGroup>
		</When>
		<When Condition="$(Configuration.Contains('2023'))">
			<PropertyGroup>
				<RevitVersion>2023</RevitVersion>
			</PropertyGroup>
		</When>
		<When Condition="$(Configuration.Contains('2024'))">
			<PropertyGroup>
				<RevitVersion>2024</RevitVersion>
			</PropertyGroup>
		</When>
		<When Condition="$(Configuration.Contains('Revit Release'))">
			<PropertyGroup>
			</PropertyGroup>
		</When>
	</Choose>
This did work fine, I added 2024 to the configuration.
When I use the "Revit Release" configuration some tools in Revit 2021 doesn't work anymore.
When I use the Build, there are some warnings but no errors.
Any ideas?
jw.vanasselt
I found the problem. I don't have a configuration for each revit release...
ricaun
Yes! Your solution needs to have the proper configuration.
I usually use the configuration like the image:
The Configurations 2018, 2019, 2020, 2021, 2022, 2023, and 2024 is Release version and the configuration with Debug is for debugging/development.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
jw.vanasselt
Thanks for the quick reply!
That make sense, exactly I am lucky, didn't use the methode too much.
Glad to find out it now 🙂
