ScheduleField.SetStyle not working as I would expect
MattKincaid
MattKincaid
I'm writing some code to modify the style of some cells in an existing schedule.  My code looks somethng like this.
Snippet
Private Sub test(field As ScheduleField)
    Dim style = New TableCellStyle
    style.FontHorizontalAlignment = HorizontalAlignmentStyle.Right
    field.SetStyle(style)
    Debug.Print(field.GetStyle.FontHorizontalAlignment.ToString)
End Sub
My debug.print statment prints "Center" everytime, which is unexpected to me.  What am I missing? All I'm trying to do is right align all the columns in a schedule.  Is there a better approach I should be taking?
I'm using 20150704_0715(x64), update release 9.  Thanks!
jeremytammik
Regenerate?
Commit?
Jeremy Tammik
Developer Technical Services
The Building Coder
MattKincaid
Thanks for the reply Jeremy.  Do you mean regenerating the document?  I sprinkled a few calls to the Regenerate routine into my test code (see below) and still experienced the same behavior.
I'm committing the transaction several levels up in the call stack so it would be complicated to post the code here.  But I can do so if you really need it.  Just let me know.
It's possible that I just have a fundamental misunderstanding regarding how transactions work.  In my sample code "field" is just a local variable that I'm passing into my routine.  I would expect any changes made to the "field" variable to be reflected even if I haven't committed the transaction. I expect that if it was an issue of not committing the transaction, my Debug.Print statement would still print "Right". Is that not how it works?  Do I need to commit the transaction immediately after my field.setStyle() call or something like that?
Thanks.
Snippet
Private Sub test(doc As Document, field As ScheduleField)
    doc.Regenerate()
    doc.Regenerate()
End Sub
jeremytammik
Dear Matt,
Yes, that is exactly what I meant.
I am not aware of any issues with these methods.
Have you taken a look at theScheduleAutomaticFormatter Revit SDK sample?
/a/lib/revit/2016/SDK/Samples/ScheduleAutomaticFormatter/CS/ScheduleFormatter.cs
That makes use of the SetStyle method.
If that does not help, all I can suggest is to implement an absolutely minimal reproducible case for the development team to analyse:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Preferable, an RVT file with an embedded macro that does nothing but the calls to set anf get the style.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
MattKincaid
Thanks for pointing me to the sample code, Jeremy.  The problem was I wasn't doing the SetCellStyleOverrideOptions calls.  I didn't know you needed to do that.  Once I added that everything worked great.  Appreciate the help.
