Schedule: Framing Type
OK, I searched all over this board for this issue and could find nothing.  If it's addressed elsewhere please link the thread.
I'm trying to create a custom framing schedule where the first column shows the "Type" of the framing element.  The remaining fields are derived from shared parameters that I'm calling by ElementId.  It works when I comment out the AddField() method for the Type.  I get a schedule containing all the instances of the remaining parameters.  Could someone point out my error in calling the framing element types?
ViewSchedule rebarSched = ViewSchedule.CreateSchedule(doc, new ElementId		(BuiltInCategory.OST_StructuralFraming));
            rebarSched.ViewName = "XXX";
            ScheduleDefinition sd = rebarSched.Definition;
            SchedulableField width = new SchedulableField(ScheduleFieldType.Instance, p_widthId);
            SchedulableField depth = new SchedulableField(ScheduleFieldType.Instance, p_depthId);
            SchedulableField topBars = new SchedulableField(ScheduleFieldType.Instance, p_topBarsId);
            SchedulableField bottomBars = new SchedulableField(ScheduleFieldType.Instance, p_bottomBarsId);
            SchedulableField tieSpacing = new SchedulableField(ScheduleFieldType.Instance, p_tieSpacingId);
ScheduleField Mark = sd.AddField(ScheduleFieldType.ElementType, new ElementId(BuiltInParameter.ALL_MODEL_TYPE_NAME));
ScheduleField Width = sd.AddField(width); ScheduleField Depth = sd.AddField(depth); ScheduleField TopBars = sd.AddField(topBars); ScheduleField BottomBars = sd.AddField(bottomBars); ScheduleField TieSpacing = sd.AddField(tieSpacing);
Nevermind.
BuiltInParameter.ELEM_TYPE_PARAM
I swear I tried that...
Any chance you could explain how you pulled the
p_widthId
I'm assuming these are the parameter ids, and I have been struggling with pulling shared parameter ids for quite some time now.
From a novice coder.
