Save to Central Error
jason.wells
jason.wells
See the attachment below this happen when someone else open the Central model and save to central the other user then can not save.
stever66
I think the first user is opening the central file, and trying to save back to the central file without creating a local file.
All users who open the central file should immediately save to a local file.  Then they work in the local file, and synchronize back to the central file.
Moustafa_K
Hi
it would be better not to double click on the file directly, as this will lead to open the Central file without creating a local file. but it would be better to open revit and then open the central file from the open menu, where in the open dialog, at the bottom, you would see a checked box says create New Local. through this each user has his own copy on his machine and they can start working and sync. as a normar worksharing proceedure.
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
jeremytammik
Dear Jason,
Did the advice from Steve and Moustafa help?
Thank you very much for your suggestions, you two!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
