Dear All,
This is to know if there are any drawbacks for this approach. While working with WPF windows, we usually use External Events and Handlers to run transactions. Here I have another approach and found working so far so good.
I have a singleton class, called TransactionRunner, which is initialized within the IExternalCommand object. The current document is then set as the value of its 'Document' property. Here is the class;
public sealed class TransactionRunner
private static TransactionRunner _instance;
private static readonly object lockobject = new object();
public Document Document { get; set; }
public string TransactionName { get; set; } = "Transaction Runner";
private TransactionRunner() { }
public static TransactionRunner Instance
get
lock (lockobject) // thread safety
if (_instance == null)
_instance = new TransactionRunner();
return _instance;
public void Execute(Action action, Action callback = null)
if (Document == null)
throw new System.Exception("Document is null");
using (Transaction t = new Transaction(Document, TransactionName))
t.Start();
action();
t.Commit();
callback?.Invoke();
In my Command;
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
uidoc = commandData.Application.ActiveUIDocument;
doc = uidoc.Document;
TransactionRunner transactionRunner = TransactionRunner.Instance;
transactionRunner.Document = doc;
// Other calls....
return Result.Succeeded;
Now I can call it like this from anywhere in the project;
TransactionRunner.TransactionName = "Some Transaction Name";
TransactionRunner.Instance.Execute(() => {
// Make changes to the document
}, _callbackToUpdateSomething);
Does the approach have any potential issues...?
