Run Dynamo script from Revit API
varshaauti27
varshaauti27
I am looking for a way to run dynamo script with Revit API programmatically.
Following code execute simple dynamo scripts successfully but unable to run dynamo script which requires user interaction (Select from dwg or input some values)
            //Get application and document objects and start transaction
            UIApplication uiapp = commandData.Application;
            Document doc = uiapp.ActiveUIDocument.Document;
            // Run dynamo script without dynamo player..
            string Journal_Dynamo_Path = @"<dynamo_script_path>";
            var dynamoRevit = new DynamoRevit();
            var dynamoRevitCommandData = new DynamoRevitCommandData
                Application = uiapp
            IDictionary<string, string> journalData = new Dictionary<string, string>
                { Dynamo.Applications.JournalKeys.ShowUiKey, false.ToString() }, // don't show DynamoUI at runtime
                { Dynamo.Applications.JournalKeys.AutomationModeKey, true.ToString() }, //run journal automatically
                { Dynamo.Applications.JournalKeys.DynPathKey, Journal_Dynamo_Path }, //run node at this file path
                { Dynamo.Applications.JournalKeys.DynPathExecuteKey, true.ToString() }, // The journal file can specify if the Dynamo workspace opened from DynPathKey will be executed or not. If we are in automation mode the workspace will be executed regardless of this key.
                { Dynamo.Applications.JournalKeys.ForceManualRunKey, false.ToString() }, // don't run in manual mode
                { Dynamo.Applications.JournalKeys.ModelShutDownKey, true.ToString() },
                { Dynamo.Applications.JournalKeys.ModelNodesInfo, false.ToString() }
            dynamoRevitCommandData.JournalData = journalData;
            Result externalCommandResult = dynamoRevit.ExecuteCommand(dynamoRevitCommandData);
            DynamoRevit.RevitDynamoModel.OpenFileFromPath(Journal_Dynamo_Path, true);
            DynamoRevit.RevitDynamoModel.ForceRun();
Tried to run script with Dynamo player itself, able to open dynamo player programmatically, but not able to run script using player.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @varshaauti27 ,
Please take a look at the below link
https://forum.dynamobim.com/t/run-a-dyn-from-a-revit-add-in/14701
It is better to discuss Dynamo-related questions in Dynamo Forum.
Please post your question in Dynamo Forum.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
varshaauti27
I am doing exactly same as mentioned in that link, this executes simple dynamo but not the one which requires user interaction.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @varshaauti27 ,
Please post your question in the Dynamo Forum
If you get no response there within a few days, please let me know.
Naveen Kumar T
