run a program from outside of Revit
avpBS7DE
avpBS7DE
Dear Revitiers,
I use Revit 2021 API, and I have crated a few External Commands, and External Applications. They all live and run from within Revit.
Now I want to create an executable that uses the RevitAPI.dll to modify a bunch of projects (.rvt) - when Revit is off.
What are my options ?
ricaun
I believe the option is Design Automation for Revit using Forge.
I have seen some users use Design Automation to test Revit plugins without open Revit.exe
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
perry.swoboda
We used RevitBatchProcessor to update a few fields in files before.  It works by running a script and starting Revit to run it.
https://github.com/bvn-architecture/RevitBatchProcessor
rhanzlick
I think this task/capability has been hotly sought-after for a long time (at least since I have been using Revit circa 2015). I have seen some seemingly nice solutions proposed over the years. Some of the best seem to be to open a session of revit, and allow your script to subscribe to the idling event. This can trigger opening/closing new documents and any other addin capabilities (like data export to databases). Just pre-allocate the project paths in a list that will be read from through a loop and it should work in theory. However, I don't think this functionality is exactly supported by autodesk, so results may vary.
As ricaun mentioned, I think the Autodesk-sanctioned way (especially recently) is to automate your workflow through Forge. I don't know much about forge, but from my understanding... that is one of the main reasons of going to the cloud (being able to batch-process over multiple models).
ricaun
I use this solution to make some tests on my application.
You could run some scripts to open some files and change stuff, but you still need Revit installed on the computer.
