Rotating Elements on their axis
recepagah12
recepagah12
I am trying to create an add-in. Rotate multiple elements with their own axis.
But element rotates angle increasing within foreach loop. I even tried constant value by ignoring user input.
The rotation angle increasing by applied elements.
I hope that's clear, Any help will be appreciated.
Recep.
double  RotateAngle;
            using (Rotating_Form thisForm = new Rotating_Form())
                // Determine the position of form
                thisForm.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
                // Show the form
                thisForm.ShowDialog();
                // Convert Radian to Degree
                RotateAngle = thisForm.Get_Angle()*Math.PI/180;
                if (thisForm.DialogResult == System.Windows.Forms.DialogResult.Cancel)
                    return Result.Cancelled;
                using (Transaction t = new Transaction(doc))
                    //Provide access to make change in document
                    t.Start("Rotate Element");
                    // Collect selected elements
                    ElementSet selection = new ElementSet();
                    //  Select element references
                    ICollection<ElementId> selectedIds = uidoc.Selection.GetElementIds();
                    foreach (ElementId elementId in selectedIds)
                        selection.Insert(uidoc.Document.GetElement(elementId));
                        foreach (Element e in selection)
                            //Get the location curve
                            Location location = e.Location;
                            LocationCurve locationCurve = location as LocationCurve;
                            Curve curve = locationCurve.Curve;
// Get the end point of curve XYZ point1 = curve.GetEndPoint(0); XYZ point2 = curve.GetEndPoint(1); // Get the mid point of curve XYZ midPoint = (point1 + point2) / 2; XYZ midHigh = midPoint.Add(XYZ.BasisZ); Line axisLine = Line.CreateBound(midPoint, midHigh); //Rotate elements on their axis bool rotated = locationCurve.Rotate(axisLine, RotateAngle); rotated = true; } } // Nothings selected if (selection.IsEmpty) { message = "Please select at least one element"; return Result.Failed; } t.Commit(); } }
Moustafa_K
have you tried this statement:
ElementTransformUtils.RotateElement(m_doc, yourelement, yourAxis, Angle);
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
