RotateElement:Element rotates temporarily and then reverts to original position
dirk.neethling
dirk.neethling
I rotate an ELement (FamilyInstance) using the following code:
Line lineAsAxis = Line.CreateBound(new XYZ(0, 0, 0), new XYZ(0, 1, 0));
double rot = ConvertToRadians(90);
ElementTransformUtils.RotateElement(doc, elem.Id, lineAsAxis, rot);
THe ELement rotates successfully, I can see it in an instant during debugging, but then reverts to its original orientation upon completion of the Execute Command. Code runs in a transaction. What could be the reason for this?
dirk.neethling
I found out I am working with adaptive Elements, thus the question is irrelevant.
