Rotate Elevation Mark 180° Issues
Hi guys,
I'm having a bit of trouble rotating elevation marks by 180°.
Currently I place Elevation markers and view index 1, then I check the view direction and rotate the view to face the wall.
The problem I have is if I try to rotate it by 1 radian(57°) anticlockwise, it works fine.
If i try to rotate the marker by 2 radians(115°) anticlockwise, it works fine.
If I try to rotate any further, for example between 3 radians (170°), it rotates it a further 180° so the marker has in effect rotated 370°.
I am using  ElementTransformUtils.RotateElement().
if anyone has any ideas, please let me know.
thanks
grahamcook
Hi
I was also having the same issue.  My post is below with a messy workaround:
https://forums.autodesk.com/t5/revit-api-forum/elevationmarker-does-not-rotate-180-deg/td-p/8010880
Graham Cook
