Rooms not placed in non-UI-document after RollBack()
Hello!
I want to modify an existing revit project without making the document visible to the user.
In this concrete case, I want to place a room into an existing house. This works fine until I use the Transaction.RollBack() method of another transaction before placing the room. In this case, the room is not placed and can also not be found in any schedule, although I can find its Id afterwards in the document when using "Search and Snoop" method of RevitLookup tool. But after saving, closing and re-opening the document, this Id doesn't exist any more. When using Transaction.Commit() instead of RollBack() in l.26 the problem does not appear.
To make my confusion complete, this problem only occurs when using Revit in english language version. In german everything works fine.
Find the code below where the room is not placed:
protected override Result ExecuteCommand(ExternalCommandData revit, ref string message, ElementSet elements)
UIApplication uiApp = revit.Application;
UIDocument uiDoc = uiApp.ActiveUIDocument;
Document doc = uiDoc.Document;
Application app = doc.Application;
Document destination = app.OpenDocumentFile("C:\\Users\\jpilarski\\Desktop\\testProject.rvt");
Level level = new FilteredElementCollector(destination)
.WherePasses(new ElementCategoryFilter(BuiltInCategory.OST_Levels))
.Where(x => x.Name == "EG- OK FFB")
.Cast<Level>()
.First();
XYZ point_a = new XYZ(-100, 0, 0);
XYZ point_b = new XYZ(-30, 0, 0);
Line line = Line.CreateBound(point_a, point_b);
Transaction trans = new Transaction(destination);
trans.Start("start transaction");
Wall wall = Wall.Create(destination, line, level.Id, false);
trans.RollBack();
View view = new FilteredElementCollector(destination)
.WherePasses(new ElementCategoryFilter(BuiltInCategory.OST_Views))
.Cast<View>()
.Where(x => x.Name.Contains("EG"))
.Where(x => x.Name.Contains("Entwurf"))
.First();
Transaction trans1 = new Transaction(destination);
trans1.Start("create room");
Room room = destination.Create.NewRoom(level, new UV(5, 5));
RoomTag roomTag = destination.Create
.NewRoomTag(new LinkElementId(room.Id), new UV(5, 5), view.Id);
trans1.Commit();
uiApp.OpenAndActivateDocument(destination.PathName);
return Result.Succeeded;
Any ideas? Thanks in advance for your answers.
Developer Advocacy and Support +
