Room separator
Room separator
johnds
Room separator
johnds
I want to create a room separator line using the API (Revit 2012), but this seems so far not possible, or am i wrong?
The does not seem to be a method anywhere to create one, which is essentially a ModelLine with a category type of OST_AreaSeparationLines. However, you cannot seem to change/assign that category to a 'standard' ModelLine after creation. Unless I've missed it.
newbie
don't you use  Document.Create.NewRoomBoundalines() to create it?
johnds
Hmmm, that method name does not really give me confidence, but i will give it a try, thanks for the suggestion.
Will post results when done.
johnds
Ok, that seemed to work! No problems so far.
If only the method name was NewRoomSeparator(...) instead! 😉
