Rider wont load referenced project Symbols after rebuild using Add-in manager
esatis
esatis
anyone here using Rider for development?
Maybe you know why Rider does not load symbols for referenced projects?
Load them only first time, then after changes and rebuild Rider does not find latest Executing-20250928_101523_4672 folder created by Add-in manager for referenced projects.
Rider only finds Symbols for main project (dll) in latest Executing folder and load them.
Referenced project Symbols are not loaded even though all symbols are in the same Executing folder next to main project.
Only after I restart Revit, all temp Executing folders are removed, and Rider loads symbols for all projects.
ricaun
I don't use Rider, but are you sure is a Rider problem?
The issue probably is in the Add-in manager, I know the original AddinManager.dll is really buggy and that's the reason I created my own version AppLoader to enable reload the plugins with Revit open.
Or you could use the RevitAddInManager version that is open-source and free.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
