RibbonPanel.AddStackedItems and SplitButton
mphelt
mphelt
Currently ribbon SplitButtons can not be created using RibbonPanel.AddStackedItems method.
Only PushButtons, PulldownButtons, ComboBoxes and TextBoxes can be added this way.
Would it be possible to remove this limitation?
jeremytammik
Dear Mphelt,
Please take into consideration that the user interface customisation possibilities supported by the Revit API are intentionally rather limited, in order to enforce a certain consistency across the default built-in UI and additional functionality provided by add-ins.
Therefore, you need to provide an extremely compelling reason for anything to be added.
Please explain in detail exactly what you are trying to achieve and why it canot be achieved in any other manner.
Maybe the easiest way for you to move forward will be to implement your own modal dialog within your own external command, in which you can implement your own user interface making use of the full range of possibilities offered by the .NET API.
A slightly more complex and powerful approach would be to implement a modeless form and user interface, again making full use of all .NET functionality, and communicate with your Revit add-in via external events, as demonstrated by the Revit SDK
ModelessForm_ExternalEvent sample.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
mphelt
Hi Jeremy,
What I wanted to achieve is a button similar to the selected one:
I've already overcome this using ribbon features from AdWindows.dll, but I was just curious whether tha lack of it in RevitAPIUI.dll is intentional or not.
Best regards,
Michał Helt
jeremytammik
Dear Michael,
Conhratulations on implementing your own workaround based on AdWindows.dll functionality.
Please note that this is unsupported and you are using that at your own risk.
Would you like to share it with us, in case other people would like to incur that risk as well?
Thank you!
I will ask the development team for you whether or not this omission is intentional.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
mphelt
var buttonData0 = new PulldownButtonData("A", "A");
var buttonData1 = new PulldownButtonData("B", "B");
var buttonData2 = new PulldownButtonData("C", "C");
var stackedItems =
  ribbonPanel.AddStackedItems(
  buttonData0,
  buttonData1,
  buttonData2
var button0 = (PulldownButton)stackedItems[0];
var splitButton = (Autodesk.Windows.RibbonSplitButton)UIFramework.RevitRibbonControl.RibbonControl.findRibbonItemById(
  string.Join(
    "CustomCtrl_",
    "CustomCtrl_",
    ribbonTabName,
    ribbonPanel.Name,
    button0.Name
splitButton.IsSplit = true;
splitButton.IsSynchronizedWithCurrentItem = true;
Dear Jeremy,
That's the cleanest solution that I have found.
Best regards,
Michał Helt
jeremytammik
Dear Michał,
Thank you very much for sharing that!
It looks perfectly clean to me.
I added it to The Building Coder as wel to make it easier to find:
http://thebuildingcoder.typepad.com/blog/2015/12/adding-a-stacked-split-button-to-the-ribbon.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
