Ribbon/Tabs
Ribbon/Tabs
Ribbon/Tabs
Hi
I´m trying to make a ribbon and the botton must call a DLL.
I want to make one dll with the all my Tabs and Ribbon witch are going to call the other DLLs
The tab and the panel with the picture works fine, but I can´t call the DLL !!
In the addin file, I have the same information to call the DLL and the FullClassName:
<Assembly>C:\ProgramData\Autodesk\Revit\Plugins\2015\BBR_Beregning.dll</Assembly>
<FullClassName>BBR_Beregning.BBR_Beregning</FullClassName>
namespace Revit_Ribbon
class AA_Ribbon : IExternalApplication
public Autodesk.Revit.UI.Result OnStartup(UIControlledApplication application)
string Panel_AA = "Aarstiderne";
application.CreateRibbonTab(Panel_AA);
RibbonPanel ribbonPanel = application.CreateRibbonPanel(Panel_AA, "ArealBeregning");
PushButtonData pushButtonDataAA = new PushButtonData("BBR", "BBR", @"C:\ProgramData\Autodesk\Revit\Plugins\2015\BBR.dll", "BBR_Beregning.BBR_Beregning");
pushButtonDataAA.AvailabilityClassName = "BBR_Beregning.BBR_Beregning";
pushButtonDataAA.ToolTip = " Aarstiderne BBR beregning";
Uri urisource = new Uri(@"C:\ProgramData\Autodesk\Revit\Plugins\2015\Pictures\BBR.png");
pushButtonDataAA.LargeImage = new BitmapImage(urisource);
ribbonPanel.AddItem(pushButtonDataAA);
return Result.Succeeded;
public Autodesk.Revit.UI.Result OnShutdown(UIControlledApplication application)
Please Help 🙂
Regards
Anders
augusto.goncalves
Your idea should work: one DLL with all ribbons, and the respective .addin file. Then this DLL point to the other DLLs, pointing to each class on them, no .addin is required for those...
From reading the code above, seems ok, but you need to make sure every DLL and class name is correct, otherwise will not work...
Looking forward, I would avoid hard-code the path like you did... assuming all DLLs are at the same folder, get the path of the executing assembly and find others on that folder.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Hi
I still got this error:
BBR_Beregning.BBR_Beregning does not inherit IExternalCommandAvailability
(BBR_Beregning.BBR_Beregning is the fullclassname)
Regards Anders
augusto.goncalves
So have you made this class "BBR_Beregning" implement the required interface (IExternalCommandAvailability)?
This is required by Revit API, the same way all command classes must implement the IExternalCommand interface
Augusto Goncalves
Hi
I have added IExternalCommandAvailability to the class, as written below.
namespace BBR_Beregning
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
public class BBR_Beregning : IExternalCommandAvailability
But I now got this error when I build the DLL File
'BBR_Beregning.BBR_Beregning' does not implement interface member 'Autodesk.Revit.UI.IExternalCommandAvailability.IsCommandAvailable(Autodesk.Revit.UI.UIApplication, Autodesk.Revit.DB.CategorySet)'
augusto.goncalves
You should keep following the instructions from the error message, in this case, the missing method
As a suggestion, in this case, when you mouse hover the IExternalCommandAvailability on Visual Studio, should appear a small blue rectangle, click on it and select "Implement interface....""
For a full sample, please check the SDK sample under "\Revit 2015 SDK\Samples\ExternalCommand\CS\ExternalCommandRegistration\AvailabilityClass.cs" (if you don't have the SDK, download from www.autodesk.com/developrevit)
Augusto Goncalves
