RFA File won't open in my Current project
akash.karsanbhai
Observer Observer
akash.karsanbhai
Observer
Observer
When I download a Revit Family from a external source such as BimObject.com, and click on the file at the bottom of my internet browser (Google Chrome), it should open in my current project with a window asking if I'd like to upgrade the file, and when I upgrade it opens up to a window where I can go to the "Family Editor", tab and Load it into my project. Instead what's happening is when I click the file at the bottom of my browser it will open up a whole new revit window where I can download the Family into a project and when I click the " Load Into Project", it says there are no open projects to load into.
jeremytammik
Please note that this discussion forum is dedicated to programming Revit using the Revit API. Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here. You should try one of the non-API Revit product support discussion forums instead for that: https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not... The people there are much better equipped to answer your question than us programming nerds. I hope this clarifies. Thank you for your cooperation and understanding. Best regards, Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
