Can anyone point me to any documentation regarding the RevitServices.dll?
I am trying to learn to use IronPython in Dynamo and clr.AddReference("RevitServices") is something I would like to understand deeper. I have decomplied the file and looked it over. I would still like to know if there is documentation covering all the functionality of whats in the RevitServices.dll.
I have search RevitServices.dll in the SDK.chm and the revitapidocs but nothing is there. Perhaps I am searching for the wrong things....
Solved by dbrokaw. Go to Solution.
I haven't researched that one yet, but some classes in the SDK require other dll files (See picture below).
Hopefully this sheds some light.
The Dynamo team presented a solution
https://forum.dynamobim.com/t/revitservices-dll-is-there-documentation/36353
@dbrokaw Getting heavy into coding now... Steep learning curve - really thinking of reexploring the Revit API (Found a Really good Linked In Learning from zero to full app)
If using Visual studio for searching - I used this to find the classes for DocumentManager - adding it into the "Custom component set" for searching.
C:\Program Files\Autodesk\Revit [####]\AddIns\DynamoForRevit\Revit\RevitServices.dll
