Revit View active with WPF window over
mizrachi_amir2
Message 1 of 12
mizrachi_amir2
I was wondering if there is any option to interact with the Revit model while my Revit plugin is active?
In other words - once I open my Revit plugin I would still like to be able to interact with the Revit model behind (selecting elements, taking measurements etc.).
Is this possible?
Thank you!
Replies (11)
Message 2 of 12
alisa_wachs_M3
You would add Topmost="True" to your Window .xaml
<Window x:Class="Test.Dialog"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:local="clr-namespace:Test"
        mc:Ignorable="d"
        Title="Your Title here" Height="300" Width="300"
        Topmost="True"
        ShowInTaskbar="False">
  <Grid>
And then interact with it through IExternalEventHandler within either of yours IExternalDBApplication, IExternalApplication, IExternalCommand class.
Dialog.Show();
/*ShowDialog() vs Show() The first opens a window and does not return until
 the newly opened window is closed. It is a modal operation, meaning it blocks
 interaction with other windows in the application until it is closed. The
 second method opens a window but immediately returns control to the caller.
 The window opened is non-modal, so other windows remain usable, and the user
 can interact with all windows concurrently.*/
handler = new PluginEvent();
ExEvent = ExternalEvent.Create(handler);
public class PluginEvent : IExternalEventHandler
  public void Execute(UIApplication app)
    // Get the current UIDocument
    UIDocument uiDoc = app.ActiveUIDocument;
    if (uiDoc != null)
      // Get the selected element from the Dialog
  public string GetName()
    return "Plugin Event";
In the .cs behind your .xaml you would use ExEvent.Raise(); thus your WPF window will give back the reins to Revit to execute Revit specific actions.
My recent post included the visual studio solution where I do everything you asked for above.
And another example of using IExternalEvent
Message 3 of 12
alisa_wachs_M3
Forum ate my response, so here's a more condensed version.
  • In your IExternalApplication / IExternalDBApplication / IExternalCommand class you create and initialize your IExternalEventHandler and also use WPFwindowName.Show(); instead of WPFwindowName.ShowDialog();
  • In WPF.xaml use Topmost="True" on your Window
  • In .xaml.cs you'd use Raise();
In my recent post I've shared visual studio solution employing all of the above, it might give you an idea of how to tie it all together. Also good idea to review would be this Autodesk page and this blog
Message 4 of 12
nd8G4SB
Hi @mizrachi_amir2 ,
If you want to create a "live" connection so that changes you make in scripts and Revit are immediately reflected in your plugin, then you should work with events. You can read more about this here:
DocumentChanged Event (revitapidocs.com)
Ajuda | Events | Autodesk
Best regards,
Nikolai Davydov
Message 5 of 12
nice3point
@mizrachi_amir2
Single-project WPF Application sample (Modeless): https://github.com/Nice3point/RevitTemplates/tree/develop/samples/SingleProjectWpfModelessApplicatio...
Pay attention to the ViewModel, it contains all the necessary interaction
Message 6 of 12
mizrachi_amir2
Hi @Anonymous
Message 7 of 12
mizrachi_amir2
Actually I am not looking for this kind of interaction. Only need an option, for instance, to take measurements in my model while my plugin in open.
Message 8 of 12
Niko_Davydov
then the answer from @nice3point  is what you need. Just work with MVVM
Best regards,
Nikolai Davydov
Message 9 of 12
Niko_Davydov
sorry, i answer from another account. @nd8G4SB ist also my account
Message 10 of 12
mizrachi_amir2
thanks @nice3point . Will take a look at your solution!
Message 11 of 12
mizrachi_amir2
thanks @nice3point . Will take a look at your solution.
Message 12 of 12
mizrachi_amir2
Thanks for this sample app.
Where can I find some instructions on how to convert my already working addin so MVVM design pattern?
