Revit Startup Menu
Revit Startup Menu
KevinBruno
Revit Startup Menu
KevinBruno
Hey everyone — I’m wondering if anyone has found a way to customize the Revit startup screen (the one that appears when you first launch Revit, with options like Open, New, Recent Files, etc.).
Ideally, I’d love to:
  • Add a custom button or link
  • Display an internal company dashboard, standards, or quick launch tools
  • Possibly even embed HTML or redirect to a SharePoint resource
Has anyone explored this? Is there an API hook, registry hack, or a creative workaround using add-ins?
Thanks in advance!
@jeremytammik or any other experts!
ricaun
The idea looks fun, but to edit the main Home probably is complicated depending what you want to do.
The main reason the Home is a plugin (ModelBrowser) inside Revit and is actually a html inside a WebBrowser.
You can find the plugin ModelBrowser inside the Revit folder:
  • %ProgramFiles%/Autodesk/Revit 2025/AddIns/ModelBrowser
If Home was a WPF would be easier to inject some extra button using an external plugin, now a html have no idea.
You still can edit the main index.html and experiment, just don't forget make a backup copy 🙃
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
