Revit shortcut doesn't work, but windows control panel says it's installed.
hroth2
Observer Observer
hroth2
Observer
Observer
Revit is already installed on my Windows laptop and when I type it into my search bar it says that the shortcut doesn't work. I cannot find it in any of my files on my desktop. I have been using this application for two years and have many important files on it that I still need to use. I looked on my control panel and it says it is still installed. What is the best option moving forward to not lose my work, but to find it, or get it running again? Thank you!
moturi.magati.george
Hi @hroth2,
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end-user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us.
  Moturi George,     Developer Advocacy and Support,  ADN Open
