Revit panel in panelTypes
I have created a family that represents panel (panello.rfa).
When I try to search that panel inside the list of panels and in Revit family it appears (panels.PNG), it is not in list
FilteredElementCollector panelTypes
                    = new FilteredElementCollector(doc)
                      .OfClass(typeof(PanelType));
                    bool found= false;
                    foreach (PanelType pt in panelTypes)
                        if ("pannello" == pt.Name)
                            windowType = pt;
                            found= true;
Can someone tell me why and how to solve?
Bruno
Charles.Piro
you must search inside Family, not in PanelType :
public Result Execute(ExternalCommandData extCmdData, ref string msg, ElementSet elmtSet)
            UIApplication uiapp = extCmdData.Application;
            UIDocument uiDoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uiDoc.Document;
            try
                string strRfa = "pannello";
                FilteredElementCollector fltElmntCol = new FilteredElementCollector(doc).OfClass(typeof(Family));
                int n = fltElmntCol.Count<Element>(e => e.Name.Equals(strRfa));
                if (0 < n)
                    Family famille = fltElmntCol.First<Element>(e => e.Name.Equals(strRfa)) as Family;
            catch (Exception e)
                msg = e.Message;
                return Result.Failed;
            return Result.Succeeded;
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
ok, understood, thank you.
But how to cast my family into paneltype? the point is that I need to insert the family pannelli.rfa in a curtaingrid. If I do it in Revit I can do it but via API I'm not able to do this because I can't find myfamily in paneltype.
                    bool found= false;
                            windowType = pt;
                            found= true;
//Try to set a panel in curtaingrid as my panel type loaded from pannelli.rfa
foreach (ElementId id in myWall.CurtainGrid.GetPanelIds())
    if (found)
             Autodesk.Revit.DB.Panel panel = doc.GetElement(id) as Autodesk.Revit.DB.Panel;
             panel.Pinned = false;
             if (pannelloVisiva != null)
                panel.PanelType = windowType ;
               break;
Thank you,
regards,
Bruno
Charles.Piro
for change, the Type of Panel in a curtainWall, you can try this :
 [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
            ElementId elmntId = null;
            ElementType famille = null;
            try
                Reference refsel = uiDoc.Selection.PickObject(ObjectType.Element, "Select Curtain Wall");
                Element elmnt = doc.GetElement(refsel.ElementId);
                Wall _wall = elmnt as Wall;
                Panel _panel = doc.GetElement(_wall.CurtainGrid.GetPanelIds().First()) as Panel;
                FilteredElementCollector fltElmntCol = new FilteredElementCollector(doc).OfClass(typeof(ElementType));
                if (0 < n)
                    famille = fltElmntCol.First<Element>(e => e.Name.Equals(strRfa)) as ElementType;
                    elmntId = famille.Id;
                using (Transaction trans = new Transaction(doc))
                    trans.Start("Change Type");
                    _panel.ChangeTypeId(elmntId);
                    trans.Commit();
            catch (Exception e)
                msg = e.Message;
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
Thank you.
It works perfectly.
Bruno
