Revit Maintaining ExternalApplication Status
I working on sample login application in Revit
Requirement:
- Revit tab has two Push-buttons, Login and upload
- Login: Opens a window form where one can enter username and password and get validated from API.
  I have created ExternalCommand for this login(dll) and hooked it in ExternalApplication.
  Now, how can I keep track of logged in status, so that next time he don't have to login again?
- Also depending the logged in status I have to enable/disable upload
matthew_taylor
Hi @Anonymous,
You need to look at IExternalCommandAvailability for enable/disable.
As for retaining login status? Depends on the scope. Forever = file or registry. Revit session = application singleton property. Document = parameter or extensible storage. Lots of possibilities.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
Thanks for your reply,
The scope I'm looking for is 'Forever', I'm new to plugin development; can you please point me towards how I can achieve this.
Thanks again
matthew_taylor
Hi @Anonymous,
You probably want to use the Registry then. (Well, it's a relatively easy way, at least!)
This link gives tips:
http://www.c-sharpcorner.com/UploadFile/f9f215/windows-registry/
You will likely need to read/write to the CurrentUser/HKEY_CURRENT_USER branch.
Stay away from deleting anything until you are *sure* what you are doing.
RegEdit is a good way to manually check/edit the registry, and also allows you to back it up.
Cheers,
-Matt
Thank you for the Answer 🙂
