Revit Macro with a User Form
How can I run a macro at the push of a command button in a user form? I tried to create a macro to rotate an element but I encountered several errors than when I run it without the user form. Also, how is the "FullClassName" determined? An image file is attached. Thanks.
recepagah12
This is not a Revit API related question. I guess you can find many answers in Stack Overflow.
Because this question directly related to the programming language you use.
I hope this helps,
Recep.
