Revit 2017.1.1 SDK
From the Getting Started with the Revit API.docx file:
> Each example file has a sample revit.ini file with the information that you will need to edit and place into the revit.ini file located in your Autodesk Revit Program folder, which Autodesk Revit will access on launch.
But I didn't find the revit.ini file neither in the "%ProgramFiles%\Autodesk\Revit 2017\" nor in the "<Revit 2017.1 SDK directory>\Samples\**\".
Is this info obsolete and this DOCX-file wasn't edited according to this change?
Also, I see this file in the "%ProgramData%\Autodesk\RVT 2017\UserDataCache\" directory. Was revit.ini file moved into this directory for Revit 2017.1.1? But at this case why this file was removed from the examples folders?
Thank you.
