Revit Extension for clash solution
Hi there,
I have a question regarding the clash detection in Revit. Is there a way I can use Revit to solve the clash problem and propose potential routes with no collisions for my model? Thank you.
jeremytammik
Are you doing anything programmatically yourself, or just using the standard Revit user interface?
If you are not doing anything programmatically, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
If you are searching for an add-in to help you address this task, I would suggest taking a look in the Revit AppStore:
https://apps.autodesk.com/RVT/en/Home/Index
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
