revit - export IFC unattended
javier.mujica
Message 1 of 12
javier.mujica
I have little or no experience with this...
but I need to write a macro in a document (*.rvt), where when opening the document the execution of the macro is launched and said macro is exported to IFC using a configuration already created in the document.
I have created a macro in C++ language and I understand that all code that I put in the "private void Module_Startup(object sender, EventArgs e)" is executed automatically when opening the document, what I need is the syntax of the code that performs the export.
thanks for any help
Replies (11)
Message 2 of 12
jeremy_tammik
Well, yes and no.
When you say, said macro is exported to IFC, I assume you actually mean, said BIM is exported to IFC.
You say, Module_Startup(object sender, EventArgs e)" is executed automatically when opening the document.
Nope, sorry to say, it is not. That method executes when your macro module is initialised.
However, you can easily execute code when the document is opened. To do so, subscribe to the DocumentOpened event:
https://www.revitapidocs.com/2022/b9415c2d-442e-f61d-aafa-de31cce7959b.htm
The code to export an IFC file is more or less a one-liner using Document.Export:
https://www.revitapidocs.com/2022/7efa4eb3-8d94-b8e7-f608-3dbae751331d.htm
Message 3 of 12
javier.mujica
Thanks for the clarification of concepts, also for giving me a starting point.
From what I understand, this is the code I have written.
As I mentioned, what I need is to open the *.RVT and run the export to IFC unattended using the "IFC4 Design Transfer View" configuration already existing in the document
*** but I get the following error when I run the macro ***
I appreciate all the help you could give me to correct the code, thanks in advance
using System;
using System.IO;
using System.Linq;
using System.Collections.Generic;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
namespace ExportIFCmodulo
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("E8D464C5-72AC-483C-BF8A-EB45BEA17DB8")]
    public partial class ThisDocument
        private void Module_Shutdown(object sender, EventArgs e)
        private void InternalStartup()
            this.Startup += new System.EventHandler(Module_Startup);
            this.Shutdown += new System.EventHandler(Module_Shutdown);
        public void ExportIFCmacro()
            string folder = "C:\\Temp\\";
            string name = this.Application.ActiveUIDocument.Document.Title;
            IFCExportOptions options = new IFCExportOptions();
            options.AddOption("ConfigName""IFC4 Design Transfer View");
            this.Application.ActiveUIDocument.Document.Export(folder, name, options);
Message 4 of 12
jeremy_tammik
One would expect the Export method to be a read-only operation.
However, apparently, it requires an open transaction to run.
That is what the error message tells you.
Here is some advice on handling transactions:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.53
Message 5 of 12
javier.mujica
Perfect!, it's already solved, I already export IFC, BUT I have a problem.
I have links in my Revit project. If I manually export with the "Export linked files as separate IFCs" checkbox enabled, I get multiple IFC files in the output.
In the code I have placed the following instruction "options.AddOption("ExportLinkedFiles", "true");" to export several IFCs, but it doesn't work! I keep exporting a single IFC without the links.
Thank you very much in advance for all the help
Message 6 of 12
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @javier.mujica ,
Could you please try using the IFCExportConfiguration class?
Please take a look at the below link
https://forums.autodesk.com/t5/revit-api-forum/ifc-export-options/td-p/9686404
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Message 7 of 12
javier.mujica
Thanks a lot
I can understand the logic that it sends me, but the creation of the instance for the IFCExportConfiguration does not work
"//Create an instance of the IFC Export Configuration Class
BIM.IFC.Export.UI.IFCExportConfiguration myIFCExportConfiguration = BIM.IFC.Export.UI.IFCExportConfiguration.CreateDefaultConfiguration();"
I'm pretty sure I need to load a gallery, dll or similar, but I can't identify what it is and especially how I do it
Thanks in advance
Message 8 of 12
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @javier.mujica .
Yes, you need to import IFCExportUI.dll.
This dll is in "C: \ Program Files \ Autodesk \ Revit 202x \ AddIns \ IFCEexporterUI \ IFCExportUI.dll".
You have to import this dll in the same way as you imported RevitAPI.dll and RevitAPIUI.dll.
Naveen Kumar T
Message 9 of 12
javier.mujica
Thank you very much for the help.
BUT, now I run into another stumbling block...
I have to set the VisibleElementsOfCurrentView to true.
configuration.VisibleElementsOfCurrentView = true
But for this above, it is necessary to define the ElementId and I do not give how to do it, since it cannot be defined as null.
ElementId ExportViewId = null
Remember my previous problem was "I have links in my Revit project. If I manually export with the "Export linked files as separate IFCs" checkbox enabled, I get multiple IFC files in the output."
Thanks in advance for everything you can help me.
Message 10 of 12
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @javier.mujica ,
Use FilteredElementCollector and get your required 3D view and pass the 3D view id to ExportViewId.
There are a lot of posts on the Revit API forum on how to get the 3D view from the document.
Could you please try this suggestion and let me know whether it helped you or not?
Naveen Kumar T
Message 11 of 12
javier.mujica
Hi everyone,
I already have the macro/api exporting the IFCs as I wanted, thanks for all your help.
I only need one thing, I have the macro/api at the application level (public partial class ThisApplication).
I need that when I open a document, any RVT document, the macro/api is executed by itself, how can I do the latter?
I can't use the "private void Module_Startup", because it only works if the macro/api is at the document level and as I said it is not the case.
thanks in advance for your help
Message 12 of 12
jeremy_tammik
In `OnStartup`, you can subscribe to `DocumentOpened`. In that event handler, you can do the dirty deed:
https://www.revitapidocs.com/2022/7e5bc7a1-0475-b2ec-0aec-c410015737fe.htm
