Revit export ddXML?
Revit export ddXML?
plawton5092
Revit export ddXML?
plawton5092
Anyone:
Since Revit's duct pressure loss calculation tools are uneven at best, is there any chance that a well-connected duct system can be exported to ddXML, so that duct pressure loss calcs can be completed in Trane VariTrane Duct Designer?
This was possible with Autocad ABS 2006, so the coding to the schema has already been done within Autodesk - can this schema be translated to C# and made part of the Revti API?
Trane has a 16-page document for the schema that I have attached.
Any help is appreciated.
Thank you
jeremytammik
Dear Peter,
Thank you for your query.
I found some mentions of the ddxml integration that you refer to ten years ago:
I doubt that this export will be integrated natively into Revit or its API.
If you would like that to happen, you should submit a wish list item for it in the Revit Idea Station and gather lots of votes for it.
A different approach might provide faster and more fruitful:
Quite probably, all of the information defined in this schema is available through the Revit API.
You can use RevitLookup to test that assumption:
https://github.com/jeremytammik/RevitLookup
It implements an interactive Revit BIM database exploration tool to view and navigate element properties and relationships.
Every data item it displays has been retrieved via the Revit API.
If all the information required by ddxml is available through RevitLookup, then you can implement your own Revit add-in to perform the desired export.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
plawton5092
Thanks, sir, for your speedy response, and for sharing your expertise.  We will investigate further, thanks again!
