Revit exceptions
Revit exceptions
Message 1 of 8
Revit exceptions
Hi, when I'm using Revit 2013 API I happened to intercept couple Revit exceptions that's been thrown, and I don't know what do they means, could you please offer some explanation and advise if these exceptions can cause any issues.
First-chance exception at 0x000007fefdb9940d in Revit.exe: Microsoft C++ exception: ShewChukException at memory location 0x0012bbb0..
First-chance exception at 0x000007fefdb9940d in Revit.exe: Microsoft C++ exception: TriangulationFailed at memory location 0x0012c128..
I do have random Revit crashes after that. Attached is the crash dump.
Thanks!
Bests,
Sen
journal.0119.txt
' 0:< Initial VM: Avail 8388383 MB, Used 17 MB, Peak 39; RAM: Avail 13368 MB, Used 40 MB, Peak 39
'C 10-Jan-2014 19:35:45.322; 0:< started recording journal file
' Build: 20120221_2030(x64)
Dim Jrn
Set Jrn = CrsJournalScript
'C 10-Jan-2014 19:35:45.324; 0:< ->DesktopMFCApp::InitApplication
'C 10-Jan-2014 19:35:45.330; 0:< <-DesktopMFCApp::InitApplication
'C 10-Jan-2014 19:35:45.330; 0:< ->DesktopMFCApp::InitNativeInstance
' 0:< Options::loadOptions: m_strDataLibraryLocations=Imperial Library=C:\ProgramData\Autodesk\RAC 2013\Libraries\US Imperial\,Imperial Detail Library=C:\ProgramData\Autodesk\RAC 2013\Libraries\US Imperial\Detail Items (defaultLib==\Library)
' 0:< ::0:: Delta VM: Avail -33 -> 8388350 MB, Used +6 -> 23 MB; RAM: Avail -14 -> 13355 MB, Used +11 -> 52 MB, Peak +11 -> 52 MB
'C 10-Jan-2014 19:35:45.374; 0:< License initialization complete
' 0:< ::0:: Delta VM: Avail -146 -> 8388205 MB, Used +22 -> 46 MB, Peak +9 -> 49 MB; RAM: Avail -55 -> 13300 MB, Used +59 -> 111 MB, Peak +59 -> 111 MB
' 0:< Initialize Trusted Utilities
' 0:< TU_MergeCentralVersion: (perm=x000a9e req=x000a8c)
' 0:< TU_OpenDocumentTask: (perm=x0001fe req=x0000bc)
' 0:< TU_FileOpenTask: (perm=x0001fe req=x0001fe)
' 0:< TU_LoadObjectSequenceTask: (perm=x00009e req=x000000)
' 0:< TU_SaveToStorage: (perm=x0001fe req=x0000bc)
' 0:< TU_OpenBackupToReloadLatest: (perm=x00009e req=x000088)
' 0:< ::0:: Delta VM: Avail -687 -> 8387518 MB, Used +129 -> 175 MB, Peak +126 -> 175 MB; RAM: Avail -143 -> 13157 MB, Used +143 -> 255 MB, Peak +143 -> 255 MB
' 0:< Autodesk Revit Architecture 2013
' 0:< 64-bit load point = E:\Revit_Architecture_2013\Revit Architecture 2013\Program
' 0:< this journal = C:\Users\KallocCliff\AppData\Local\Autodesk\Revit\Autodesk Revit Architecture 2013\Journals\journal.0119.txt
' 0:< ::0:: Delta VM: Avail -51 -> 8387468 MB, Used +7 -> 183 MB, Peak +38 -> 214 MB; RAM: Avail -14 -> 13144 MB, Used +11 -> 266 MB, Peak +13 -> 268 MB
' 0:< Journal Init
' 0:< Log Summary
' 0:< .Count
' 0:< ...closeHiddenWindowsInAllDocuments = 1
' 0:< ...onUpdateWindowCloseHidden = 1
' 0:< .ThreadPool
' 0:< ...ActivePoolSize = 20
' 0:< ...ConfiguredPoolSize = automatic
' 0:< ...ParallelCores = 8
' 0:< ...RequestedPoolSize = automatic
' 0:< .Tuning
' 0:< ...ElemTable = 1 (Serial except when multithreaded)
' 0:< ...Global = 0 (Scalable)
' 0:< ...NativeForArr = 1 (Native)
' 0:< ...PoolGlobal = 1 (Pool)
' 0:< ...PoolLocking = 1 (Locking)
' 0:< ...PoolScalable = 1 (Pool)
' 0:< ...PoolTreeNodes = 0 (Allocator)
' 0:< ...Scalable = 0 (Scalable)
'H 10-Jan-2014 19:35:53.734; 0:<
Jrn.Data "JournalDefaultTemplate" _
, "Architectural Template=$AllUsersAppData\Templates\US Imperial\default.rte, Construction Template=$AllUsersAppData\Templates\US Imperial\Construction-Default.rte"
Jrn.Data "JournalDefaultViewDiscipline" _
, "Architecture"
Jrn.Directive "Version" _
, "2013.000", "2.137"
Jrn.Directive "Username" _
, "KallocCliff"
Jrn.Directive "CategoryDisciplineFilter" _
, -1
Jrn.Directive "DisciplineOption" _
, 7677
Jrn.Directive "TabDisplayOptions" _
, "StayOnModifyInProject", 0
, "StayOnModifyInFamily", 1
, "ActiveCtOnSelection", 1
' 0:< ::0:: Delta VM: Avail -93 -> 8387376 MB, Used +39 -> 222 MB, Peak +11 -> 225 MB; RAM: Avail -30 -> 13114 MB, Used +30 -> 297 MB, Peak +29 -> 297 MB
' 0:< Added new API external application RaaS, class Autodesk.RaaS.RevitAddin.EApplication, assembly RaaSApplication.dll, vendorId ADSK, vendor description Autodesk, www.autodesk.com.
' 0:< API registering ApplicationClosing event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408).
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' Executed implementation with implementation from application 'RaaS' dll 'E:\Revit_Architecture_2013\Revit Architecture 2013\Program\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command Executed event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_IN_CLOUD' CanExecute implementation with implementation from application 'RaaS' dll 'E:\Revit_Architecture_2013\Revit Architecture 2013\Program\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { API registering command CanExecute event by application RaaS (d4f6554b-5d68-4a13-beec-4a0647c34408). }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' Executed implementation with implementation from application 'RaaS' dll 'E:\Revit_Architecture_2013\Revit Architecture 2013\Program\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< API_SUCCESS { Replacing command id 'ID_PHOTO_RENDER_GALLERY' CanExecute implementation with implementation from application 'RaaS' dll 'E:\Revit_Architecture_2013\Revit Architecture 2013\Program\AddIns\RaaSForRevit\RaaSApplication.dll'. }
' 0:< Added new API external application Fuzor, class Fuzor.CsAddpanel, assembly C:\ProgramData\Autodesk\Revit\Addins\2013\library\Fuzor.dll, vendorId ADSK, vendor description Kalloc Studios, Inc. http://www.kalloctech.com.
' 0:< Added new API pushbutton 6400 name text Launch Fuzor class Fuzor.Command assembly C:\ProgramData\Autodesk\Revit\Addins\2014\library\Fuzor.dll
' 0:< Added new API pushbutton 6401 name text Clear Scene class Fuzor.NewSceneCommand assembly C:\ProgramData\Autodesk\Revit\Addins\2014\library\Fuzor.dll
' 0:< Added new API pushbutton 6402 name text Generate Cache class Fuzor.SaveCommand assembly C:\ProgramData\Autodesk\Revit\Addins\2014\library\Fuzor.dll
' 0:< Added new API pushbutton 6403 name text View Sync On class Fuzor.CameraSyncCommand assembly C:\ProgramData\Autodesk\Revit\Addins\2014\library\Fuzor.dll
' 0:< Added new API pushbutton 6404 name text Linkfile Manager class Fuzor.LinkFileCommand assembly C:\ProgramData\Autodesk\Revit\Addins\2014\library\Fuzor.dll
' 0:< Added new API pushbutton 6405 name text Edit Selection class Fuzor.FocusObjectCommand assembly C:\ProgramData\Autodesk\Revit\Addins\2014\library\Fuzor.dll
' 0:< Added new API pushbutton 6406 name text Texture Correction class Fuzor.AdjustMaterialCommand assembly C:\ProgramData\Autodesk\Revit\Addins\2014\library\Fuzor.dll
' 0:< ::0:: Delta VM: Avail -17 -> 8387360 MB, Used -2 -> 220 MB, Peak +0 -> 226 MB; RAM: Avail +0 -> 13115 MB, Used 297 MB, Peak +4 -> 302 MB
' 0:< API registering DocumentOpening event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentOpened event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentCreating event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentCreated event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< Added new API external application Revit Lookup, class RevitLookup.App, assembly C:\ProgramData\Autodesk\Revit\Addins\2013\library\RevitLookup.dll, vendorId ADSK, vendor description Autodesk, www.autodesk.com.
' 0:< Added new API pushbutton 6407 name text Hello World... class RevitLookup.HelloWorld assembly C:\ProgramData\Autodesk\Revit\Addins\2013\library\RevitLookup.dll
' 0:< Added new API pushbutton 6408 name text Snoop DB... class RevitLookup.CmdSnoopDb assembly C:\ProgramData\Autodesk\Revit\Addins\2013\library\RevitLookup.dll
' 0:< Added new API pushbutton 6409 name text Snoop Current Selection... class RevitLookup.CmdSnoopModScope assembly C:\ProgramData\Autodesk\Revit\Addins\2013\library\RevitLookup.dll
' 0:< Added new API pushbutton 6410 name text Snoop Application... class RevitLookup.CmdSnoopApp assembly C:\ProgramData\Autodesk\Revit\Addins\2013\library\RevitLookup.dll
' 0:< Added new API pushbutton 6411 name text Test Framework... class RevitLookup.CmdTestShell assembly C:\ProgramData\Autodesk\Revit\Addins\2013\library\RevitLookup.dll
' 0:< Added new API pushbutton 6412 name text Events... class RevitLookup.CmdEvents assembly C:\ProgramData\Autodesk\Revit\Addins\2013\library\RevitLookup.dll
' 0:< API registering DocumentClosed event by application Revit Lookup (356cda5a-e6c5-4c2f-a9ef-b3222116b8c8).
' 0:< API registering DocumentOpened event by application Revit Lookup (356cda5a-e6c5-4c2f-a9ef-b3222116b8c8).
' 0:< API registering DocumentSaved event by application Revit Lookup (356cda5a-e6c5-4c2f-a9ef-b3222116b8c8).
' 0:< API registering DocumentSavedAs event by application Revit Lookup (356cda5a-e6c5-4c2f-a9ef-b3222116b8c8).
'C 10-Jan-2014 19:35:55.322; 0:< ->processShellCommand
'E 10-Jan-2014 19:35:55.322; 0:<
Jrn.Command "Internal" , "Show or hide recent files , ID_STARTUP_PAGE"
' 0:< ::1:: Delta VM: Avail -18 -> 8387342 MB, Used +1 -> 221 MB, Peak +6 -> 232 MB; RAM: Avail -6 -> 13110 MB, Used +4 -> 301 MB, Peak +8 -> 310 MB
'C 10-Jan-2014 19:35:55.414; 0:< <-processShellCommand
'C 10-Jan-2014 19:35:55.414; 0:< ->DesktopMFCApp::doStartupWarnings
'C 10-Jan-2014 19:35:55.414; 0:< manage involvement
'C 10-Jan-2014 19:35:55.415; 0:< manage licensing
' 0:< License mode: Standalone
' 0:< Status: Your license is non-expiring.
' 0:< Type: Standalone - Locked
' 0:< Usage: Not For Resale Version
' 0:< Behavior: Permanent
' 0:< Expiration: None
'C 10-Jan-2014 19:35:55.827; 0:< manage debug modes
'C 10-Jan-2014 19:35:55.828; 0:< MFCApp::testGraphicsHardware
' 0:< ::1:: Delta VM: Avail -40 -> 8387302 MB, Used +1 -> 223 MB; RAM: Avail -8 -> 13102 MB, Used +7 -> 309 MB
' 0:< Revit Graphics Information
' 0:< Current Mode : DirectX Hardware
' 0:< Use Hardware: ON
' 0:< Use Overlays : ON
' 0:< useNullDevice=false
' 0:< START CanUseHardware(forced)
' 1:< ::1:: Delta VM: Avail -78 -> 8387225 MB, Used +62 -> 286 MB, Peak +54 -> 287 MB; RAM: Avail -15 -> 13088 MB, Used +12 -> 322 MB, Peak +12 -> 323 MB
' 1:< DX Device: DirectX 11, Hardware
'C 10-Jan-2014 19:35:55.908; 1:< START video card certification
' 1:< ::1:: Delta VM: Avail -91 -> 8387134 MB, Used +10 -> 296 MB, Peak +10 -> 298 MB; RAM: Avail -20 -> 13069 MB, Used +22 -> 344 MB, Peak +23 -> 347 MB
' 1:<
'Current driver version: 8.17.13.142
'Certified driver(s):
' 1:< VIDEO CARD ENVIRONMENT: CARD="NVIDIA GeForce GT 640" ManufacturerID="10DE" DeviceID="0FC1" osID="2000" DRIVER="8.17.13.142" DEVICE="DX11" FL_Caps="50" (Shader Model)
'C 10-Jan-2014 19:35:56.077; 1:< FINISH video card certification
' 1:<
'Can use hardware=y
'Hardware support flags:
'FeatureLevelLow=n
'DrvOlderThanTested=n
'DrvNewerThanTested=n
'CardIsNotListed=y
'NotCertifiedEnv=n
'3GBSwitchIsOn=n
'SoftwareModeForced=n
' 0.232253 1:<<CanUseHardware(forced)
' 0:< FINISH CanUseHardware(forced)
'C 10-Jan-2014 19:35:56.077; 0:< postConditionalWarnings
'C 10-Jan-2014 19:35:56.077; 0:< giveAtomRegistrationWarnings
'C 10-Jan-2014 19:35:56.077; 0:< warnings->consumeAll
'C 10-Jan-2014 19:35:56.078; 0:< Process result of DebugModes-Changed Task Dialog
'C 10-Jan-2014 19:35:56.078; 0:< isMaterialLibraryAvailable
'C 10-Jan-2014 19:35:56.078; 0:< start up warnings for AddIns
'C 10-Jan-2014 19:35:56.079; 0:< <-DesktopMFCApp::doStartupWarnings
'C 10-Jan-2014 19:35:56.079; 0:< <-DesktopMFCApp::InitNativeInstance
'C 10-Jan-2014 19:35:56.079; 0:< ->DesktopMFCApp::InitManagedInstance
'C 10-Jan-2014 19:35:56.079; 0:< <-DesktopMFCApp::InitManagedInstance
' 0:< ::1:: Delta VM: Avail -41 -> 8387093 MB, Used +11 -> 308 MB, Peak +10 -> 308 MB; RAM: Avail -13 -> 13057 MB, Used +19 -> 363 MB, Peak +17 -> 364 MB
'C 10-Jan-2014 19:35:56.332; 0:< appPriv idle
' 0:< OPERATING SYSTEM INFORMATION:
' 0:< BuildNumber : 7601
' 0:< BuildType : Multiprocessor Free
' 0:< Caption : Microsoft Windows 7 Professional
' 0:< CodeSet : 1252
' 0:< CountryCode : 1
' 0:< CSDVersion : Service Pack 1
' 0:< FreePhysicalMemory : 13367492
' 0:< FreeSpaceInPagingFiles : 15725356
' 0:< FreeVirtualMemory : 27831340
' 0:< MaxProcessMemorySize : 8589934464
' 0:< OSLanguage : 1033
' 0:< OSType : 18
' 0:< ServicePackMajorVersion : 1
' 0:< ServicePackMinorVersion : 0
' 0:< TotalVirtualMemorySize : 32921368
' 0:< TotalVisibleMemorySize : 16461616
' 0:< Version : 6.1.7601
' 0:< Process affinity mask : FF
' 0:< System affinity mask : FF
' 0:< PROCESSOR INFORMATION:
' 0:< AddressWidth : 64
' 0:< Architecture : 9
' 0:< Availability : 3
' 0:< Caption : Intel64 Family 6 Model 58 Stepping 9
' 0:< CurrentClockSpeed : 3501
' 0:< DataWidth : 64
' 0:< Description : Intel64 Family 6 Model 58 Stepping 9
' 0:< Family : 191
' 0:< L2CacheSize : 256
' 0:< Level : 6
' 0:< Manufacturer : GenuineIntel
' 0:< MaxClockSpeed : 3501
' 0:< Name : Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
' 0:< ProcessorType : 3
' 0:< Revision : 14857
' 0:< Role : CPU
' 0:< SocketDesignation : LGA1155
' 0:< StatusInfo : 3
' 0:< Version :
' 0:< VIDEO CONTROLLER INFORMATION:
' 0:< AdapterCompatibility : NVIDIA
' 0:< AdapterDACType : Integrated RAMDAC
' 0:< AdapterRAM : -2147483648
' 0:< Caption : NVIDIA GeForce GT 640
' 0:< CurrentBitsPerPixel : 32
' 0:< CurrentHorizontalResolution : 1440
' 0:< CurrentNumberOfColors : 4294967296
' 0:< CurrentRefreshRate : 59
' 0:< CurrentVerticalResolution : 900
' 0:< Description : NVIDIA GeForce GT 640
' 0:< DriverDate : 20120515000000.000000-000
' 0:< DriverVersion : 8.17.13.142
' 0:< MaxRefreshRate : 75
' 0:< MinRefreshRate : 50
' 0:< Monochrome : 0
' 0:< Name : NVIDIA GeForce GT 640
' 0:< VideoArchitecture : 5
' 0:< VideoMemoryType : 2
' 0:< VideoModeDescription : 1440 x 900 x 4294967296 colors
' 0:< VideoProcessor : GeForce GT 640
' 0:< AdapterCompatibility : Intel Corporation
' 0:< AdapterDACType : Internal
' 0:< AdapterRAM : -1879048192
' 0:< Caption : Intel(R) HD Graphics 4000
' 0:< Description : Intel(R) HD Graphics 4000
' 0:< DriverDate : 20120319000000.000000-000
' 0:< DriverVersion : 8.15.10.2696
' 0:< MaxRefreshRate : 0
' 0:< Name : Intel(R) HD Graphics 4000
' 0:< VideoProcessor : Intel(R) HD Graphics Family
' 0:< PRINTER INFORMATION:
' 0:< Caption : Microsoft XPS Document Writer
' 0:< Default : 0
' 0:< DeviceID : Microsoft XPS Document Writer
' 0:< Direct : 0
' 0:< DriverName : Microsoft XPS Document Writer
' 0:< EnableBIDI : 0
' 0:< EnableDevQueryPrint : 0
' 0:< HorizontalResolution : 600
' 0:< Local : -1
' 0:< Name : Microsoft XPS Document Writer
' 0:< Network : 0
' 0:< PortName : XPSPort:
' 0:< PrintJobDataType : RAW
' 0:< PrintProcessor : winprint
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< SpoolEnabled : -1
' 0:< VerticalResolution : 600
' 0:< Caption : Fax
' 0:< Default : 0
' 0:< DeviceID : Fax
' 0:< Direct : 0
' 0:< DriverName : Microsoft Shared Fax Driver
' 0:< HorizontalResolution : 200
' 0:< Local : -1
' 0:< Name : Fax
' 0:< Network : 0
' 0:< PortName : SHRFAX:
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< VerticalResolution : 200
' 0:< Caption : Brother HL-4070CDW series
' 0:< Default : -1
' 0:< DeviceID : Brother HL-4070CDW series
' 0:< Direct : 0
' 0:< DriverName : Brother HL-4070CDW series
' 0:< Local : -1
' 0:< Name : Brother HL-4070CDW series
' 0:< Network : 0
' 0:< PortName : BRNF2592B
' 0:< RawOnly : 0
' 0:< Shared : 0
' 0:< PRINTER CONFIGURATION INFORMATION:
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Microsoft XPS Document Writer
' 0:< DriverVersion : 1536
' 0:< Duplex : 0
' 0:< Orientation : 1
' 0:< PaperLength : 2794
' 0:< PaperSize : Letter 8 1/2 x 11 in
' 0:< PaperWidth : 2159
' 0:< PrintQuality : 600
' 0:< SpecificationVersion : 1025
' 0:< XResolution : 600
' 0:< YResolution : 600
' 0:< Color : 1
' 0:< Description : Fax
' 0:< DriverVersion : 1024
' 0:< Duplex : 0
' 0:< PrintQuality : 200
' 0:< XResolution : 200
' 0:< YResolution : 200
' 0:< Color : 2
' 0:< Copies : 1
' 0:< Description : Brother HL-4070CDW series
' 0:< DriverVersion : 268
' 0:< Duplex : 0
'E 10-Jan-2014 19:35:59.239; 0:<
Jrn.Command "StartupPage" , "Open this project , ID_FILE_MRU_FIRST"
'H 10-Jan-2014 19:35:59.239; 0:<
Jrn.Data "MRUFileName" _
, "..\..\..\..\..\..\Desktop\CCCUB_2013.rvt"
' 1:< ::2:: Delta VM: Avail -14 -> 8387080 MB, Used +1 -> 309 MB, Peak +1 -> 309 MB; RAM: Avail -9 -> 13049 MB, Used +6 -> 370 MB, Peak +6 -> 370 MB
' 1:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 1:< RAM Statistics: 13049 / 16075 370=InUse 370=Peak
' 1:< VM Statistics: 8387080 / 8388607 309=InUse 309=Peak
'C 10-Jan-2014 19:35:59.308; 2:< File: Open
' 3:< Connecting session [$5f70ee9d] to Worksharing Log [C:\Users\KallocCliff\AppData\Local\Autodesk\Revit\Autodesk Revit Architecture 2013\Journals\journal.0119.txt]
' 0.000013 4:<<<WorksharingLog::getSlog []
' 3:< Additional IP address/name found for host KallocCliff-PC: 192.168.0.128
' 3:< Additional IP address/name found for host KallocCliff-PC: 192.168.1.128
' 4:< ::2:: Delta VM: Avail -625 -> 8386455 MB, Used +1 -> 310 MB, Peak +1 -> 311 MB; RAM: Avail -3 -> 13046 MB, Used +1 -> 371 MB, Peak +1 -> 372 MB
' 4:< LPSTORAGE ACQUIRED: MFCDocStorage=0x127e8a00, plpRootStg=0x12a464b8, lpRootStg=0x129d4090
' 0.000788 4:<<acquireFileLock
' 0.001428 3:<<OpenDocumentTask::acquireFileLock
' 0.052537 6:<<<DictionaryAnalysis::initialize
' 0.013059 6:<<<loadAllClasses
' 0.000052 6:<<<RegisterPreDocLoadCallback::invokeCallbacks
' 0.001672 7:<<<LoadModel DSI
' 0.001814 6:<<loading DocumentStorageIndex
' 5:< Connecting session [$9c5ff523] to Worksharing Log [C:\Users\KallocCliff\AppData\Local\Autodesk\Revit\Autodesk Revit Architecture 2013\Journals\journal.0119.txt]
' 0.000021 6:<<<WorksharingLog::getSlog [\\vmwfs0007\v20\cbes\General\BIM\BIM Admin\References\Reference Project\CCCUB_2011.rvt]
' 5:< Additional IP address/name found for host KallocCliff-PC: 192.168.0.128
' 5:< Additional IP address/name found for host KallocCliff-PC: 192.168.1.128
' 5:< DBG_INFO: Get addresses failed (using getaddrinfo) for central server vmwfs0007: No such host is known. : line 621 of n:\build\2013_ship_x64_inst_20120221_2030\source\revit\revitdb\permissions\WorksharingLog.cpp.
' 5:< SLOG $9c5ff523 2014-01-10 19:36:01.929 >Session $9c5ff523
' 5:< SLOG user="KallocCliff"
' 5:< SLOG build="20120221_2030(x64)"
' 5:< SLOG journal="C:\Users\KallocCliff\AppData\Local\Autodesk\Revit\Autodesk Revit Architecture 2013\Journals\journal.0119.txt"
' 5:< SLOG host=::1 "KallocCliff-PC"
' 5:< SLOG server=??.??.??.?? "???.com"
' 5:< SLOG central="\\vmwfs0007\v20\cbes\General\BIM\BIM Admin\References\Reference Project\CCCUB_2011.rvt"
' 5:< SLOG local="C:\Users\KallocCliff\Desktop\CCCUB_2013.rvt"
' 5:< SLOG timer="pulse-9c5ff523.tmp"
' 5:< SLOG timebias=480
' 2.551802!!!!!! 5:!!!BIG_GAP LoadSerialize
' 6:< Threaded version of fileExists is enabled. 2.558 seconds elapsed for threaded fileExists \\vmwfs0007\v20\cbes\General\BIM\BIM Admin\References\Reference Project\CCCUB_2011.rvt
' 2.552006 6:<<<fileExists?
' 5:< SLOG $9c5ff523 2014-01-10 19:36:04.481 >Open
' 0.000285 6:<<<fileExists?
' 5:< SLOG $9c5ff523 2014-01-10 19:36:04.482 >Open:Local "C:\Users\KallocCliff\Desktop\CCCUB_2013.rvt"
' 0.000267 6:<<<fileExists?
' 5:< fileSizeOnOpen:319616KB
'E 10-Jan-2014 19:36:04.483; 6:<
' [Jrn.BasicFileInfo] Rvt.Attr.Worksharing: Local Rvt.Attr.UserName: KallocCliff Rvt.Attr.CentralModelPath: \\vmwfs0007\v20\cbes\General\BIM\BIM Admin\References\Reference Project\CCCUB_2011.rvt Rvt.Attr.RevitBuildVersion: Autodesk Revit Architecture 2013 (Build: 20120221_2030(x64)) Rvt.Attr.LastSavePath: W:\Shared Revit Files\Revit 2013 Test Files\CCCUB_2013.rvt Rvt.Attr.LT: notLT Rvt.Attr.LocaleWhenSaved: ENU
' 6:< ::3:: Delta VM: Avail -15 -> 8386441 MB, Used +14 -> 325 MB, Peak +14 -> 325 MB; RAM: Avail -15 -> 13032 MB, Used +17 -> 388 MB, Peak +16 -> 388 MB
' 0.069552 7:<<<app infos and other global data
' 6:< File was saved in Autodesk Revit Architecture 2013 (Build: 20120221_2030(x64))
' 7:< ::3:: Delta VM: Avail -159 -> 8386282 MB, Used +168 -> 493 MB, Peak +168 -> 493 MB; RAM: Avail -174 -> 12859 MB, Used +173 -> 561 MB, Peak +173 -> 561 MB
' 0.008232 8:<<<ET::repairModificationDatesOutOfSequence
' 7:< Loaded ElemTable: Size=827348
' 0.323958 7:<<ElemTable
' 0.000081 7:<<<ContentDocuments
' 6:< ::3:: Delta VM: Avail -20 -> 8386262 MB, Used +20 -> 514 MB, Peak +20 -> 514 MB; RAM: Avail -27 -> 12833 MB, Used +26 -> 588 MB, Peak +26 -> 588 MB
' 1.055639 7:<<<History
' 0.000242 7:<<<increment table
' 6:< SLOG $9c5ff523 2014-01-10 19:36:05.933 .Open:Local:LFV central=65 local=1
' 0.000190 7:<<<fileExists?
' 6:< ::3:: Delta VM: Avail -17 -> 8386245 MB, Used +1 -> 516 MB, Peak +1 -> 516 MB; RAM: Avail -4 -> 12829 MB, Used +2 -> 590 MB, Peak +2 -> 590 MB
' 0.012592 7:<<<WorksetTable
' 0.000014 7:<<<partitionStorageLock.open
' 0.000026 8:<<<loadLatestVersionsEstimate
' 8:< ::3:: Delta VM: Avail -546 -> 8385700 MB, Used +531 -> 1047 MB, Peak +531 -> 1047 MB; RAM: Avail -2056 -> 10774 MB, Used +831 -> 1422 MB, Peak +831 -> 1422 MB
' 8:< Loaded elemStream#0: uncompSize=313567511, compSize=313567801, count=827348
' 3.436561 8:<<<loadLatestVersion
' 8:< ::3:: Delta VM: Avail 8385700 MB, Used 1047 MB; RAM: Avail +11 -> 10786 MB, Used 1422 MB
' 0.136002 9:<<<ElementStorageSwapout::restore()
' 0.000003 9:<<<ElementStorageSwapout::restore()
' 0.136162 8:<<els.commit
' 3.572848 7:<<loadSelectedPartitions
' 5:< ::3:: Delta VM: Avail 8385700 MB, Used 1047 MB; RAM: Avail +11 -> 10797 MB, Used 1422 MB
' 5.334695 6:<<DocumentStorageIndexImpl::loadDocument()
' 7:< Current project ADocument version:2655
' 7:< DBG_INFO: The following untracked moribund element(s) have been discovered in the newly opened document: 16146222 - Alignment, 16146223 - Alignment, 16146224 - Alignment, 16146225 - Alignment. : line 5920 of n:\build\2013_ship_x64_inst_20120221_2030\source\revit\revitdb\document\Document.cpp.
' 8:< ::3:: Delta VM: Avail -266 -> 8385435 MB, Used +172 -> 1220 MB, Peak +267 -> 1314 MB; RAM: Avail +295 -> 11093 MB, Used +173 -> 1595 MB, Peak +266 -> 1688 MB
' 5.894043 9:<<<updating dependencies in delayed deletion
' 0.033364 9:<<<getAllNonexistentParents in delayed deletion
' 8:< ::3:: Delta VM: Avail 8385435 MB, Used 1220 MB; RAM: Avail +17 -> 11111 MB, Used 1595 MB
' 0.166328 9:<<<findAppInfoNonexistentParents in delayed deletion
' 6.094074 8:<<delayed deletion
' 0.028730 8:<<<forceResetOfElemRecOwnerCache
' 7:< The following untracked moribund element(s) were discovered when this document was loaded, and still have not been deleted: 16146222 - Alignment, 16146223 - Alignment, 16146224 - Alignment, 16146225 - Alignment. Robert Stairs, 16-Apr-2009
' 6:< ::3:: Delta VM: Avail 8385435 MB, Used 1220 MB; RAM: Avail +11 -> 11123 MB, Used 1595 MB
' 6.329757 7:<<ADocumentUpgrade::docUpgrade
' 16.873665 4:<<LoadSerialize/ALL_GAPS 2.589173/TurnOff_GAPs 100%
' 16.873772 3:<<LoadFromStorage
' 3:< ::3:: Delta VM: Avail +624 -> 8386060 MB, Used -2 -> 1218 MB; RAM: Avail +314 -> 11437 MB, Used -313 -> 1282 MB
' 3:< LPSTORAGE RELEASED: plpRootStg=0x12a464b8, lpRootStg=0x129d4090
' 3:< AFTER RELEASE: plpRootStg=0x12a464b8, lpRootStg=0x00000000
' 0.015898 3:<<<relinquishAllLocks
' 2:< SLOG $9c5ff523 2014-01-10 19:36:16.200 <Open:Local
' 0.000193 3:<<<fileExists?
' 0.000111 3:<<<fileExists?
' 0.069132 4:<<<forceResetOfElemRecOwnerCache
' 5:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 5:< RAM Statistics: 11445 / 16075 1283=InUse 1688=Peak
' 5:< VM Statistics: 8386058 / 8388607 1218=InUse 1314=Peak
' 5:< 000000001276F8D0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 5:< 000000001276F9D0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 5:< 000000001276FAD0 CompactMemoryManager Memory Statistics: 256 MB with 2 MB view
' 5:< 000000001276FBD0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 5:< 000000001276FCD0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 5:< 000000001276FDD0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 5:< 000000001276FED0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 5:< 0000000044932D10 CompactMemoryManager Memory Statistics: 256 MB with 2 MB view
' 5:< Element Expansion Statistics:
' 5:< 0% Opening Plans (0)
' 5:< 0% Opening RC Plans (0)
' 5:< 0% Opening 3d Views (0)
' 5:< 0% Opening Elevations and Sections (0)
' 5:< 0% In Regnerate (0)
' 5:< 0% In Autojoin (0)
' 5:< 0% In Overlap Checking (0)
' 5:< 0% Reviewing PostedWarnings (0)
' 5:< 100% Other (3818)
' 5:< total bytes expanded: 3818
' 5:< ;EES;0;0;0;0;0;0;0;0;100;
' 5:< ::3:: Delta VM: Avail -2 -> 8386058 MB, Used 1218 MB; RAM: Avail +50 -> 11487 MB, Used +0 -> 1283 MB
' 0.001436 6:<<<ppg constructor
' 0.000009 6:<<<updating dependencies in dp
' 0.000015 6:<<<notifyAppInfosOfDP(0)
' 0.000001 7:<<<updating dependencies in delayed deletion
' 0.032449 7:<<<getAllNonexistentParents in delayed deletion
' 6:< ::3:: Delta VM: Avail 8386058 MB, Used 1218 MB; RAM: Avail +18 -> 11506 MB, Used 1283 MB
' 0.166448 7:<<<findAppInfoNonexistentParents in delayed deletion
' 0.000014 7:<<<notifyAppInfosOfDP(1)
' 0.199148 6:<<delayed deletion
' 0.717049 5:<<ADocumentMerge::delayedPropagation
' 0.002069 6:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.000182 6:<<<EndOrAbortUndoTransaction()--AtomViewReferencingUpdate();DOPT;
' 6:< ::3:: Delta VM: Avail -12 -> 8386046 MB, Used 1218 MB; RAM: Avail +12 -> 11518 MB, Used +1 -> 1284 MB
' 0.000003 7:<<<EndOrAbortUndoTransaction()--end of transaction checks--invisible elements;DOPT;
' 0.000016 8:<<<;PERF;MISC;regenerating
' 0.000190 6:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000171/TurnOff_GAPs 14%
' 4:< ::3:: Delta VM: Avail +16 -> 8386062 MB, Used +23 -> 1242 MB; RAM: Avail -12 -> 11507 MB, Used +18 -> 1303 MB
' 0.155813 5:<<EndOrAbortUndoTransaction();DOPT;
' 0.933590 4:<<delayed propagation on open
' 0.000007 4:<<<updating dependencies on open
' 4:< ::3:: Delta VM: Avail -16 -> 8386046 MB, Used 1242 MB; RAM: Avail +223 -> 11730 MB, Used +1 -> 1304 MB
' 4:< Threaded version of fileExists is enabled. 2.543 seconds elapsed for threaded fileExists \\lpt-hk8\arch\05595\Archive\20070309_GBP re-submission\Area Calculation\Site coverage.dwg
' 2.552549!!!!!! 5:!!!BIG_GAP reloadLinkedInstances [1/21]
' 0.000023 6:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.000004 6:<<<EndOrAbortUndoTransaction()--AtomViewReferencingUpdate();DOPT;
' 0.000002 7:<<<EndOrAbortUndoTransaction()--end of transaction checks--invisible elements;DOPT;
' 0.000051 8:<<<;PERF;MISC;regenerating
' 0.000277 6:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000224/TurnOff_GAPs 30%
' 0.010604 5:<<EndOrAbortUndoTransaction();DOPT;
' 2.563260 4:<<reloadLinkedInstances [1/21]
' 0.000009 5:<<<;PERF;MISC;regenerating
' 0.000012 5:<<<EndOrAbortUndoTransaction() -- trackers regen;DOPT;
' 0.000003 5:<<<EndOrAbortUndoTransaction()--AtomViewReferencingUpdate();DOPT;
' 0.000001 6:<<<EndOrAbortUndoTransaction()--end of transaction checks--invisible elements;DOPT;
' 0.000008 7:<<<;PERF;MISC;regenerating
' 0.000214 5:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000205/TurnOff_GAPs 30%
' 0.009807 4:<<EndOrAbortUndoTransaction();DOPT;
' 0.000002 6:<<<EndOrAbortUndoTransaction()--end of transaction checks--invisible elements;DOPT;
' 0.000011 7:<<<;PERF;MISC;regenerating
' 0.000216 5:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000204/TurnOff_GAPs 30%
' 0.009364 4:<<EndOrAbortUndoTransaction();DOPT;
' 4:< No Keynote File: P:\05595\CADD\595 CAD ADMIN\Revit Keynote\AED595-Keynotes.txt
' 4:< DBG_INFO: Couldn't obtain time/date stamp for P:\05595\CADD\595 CAD ADMIN\Revit Keynote\AED595-Keynotes.txt so that cannot correct file create/access/modify time!, the GetLastError is 6: line 2195 of FileUtil.cpp.
' 0.000420 4:<<<pKeynoteTable->readFile
' 0.000007 5:<<<;PERF;MISC;regenerating
' 0.000003 7:<<<;PERF;MISC;regenerating
' 0.000085 5:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;/ALL_GAPS 0.000081/TurnOff_GAPs 29%
' 0.005726 4:<<EndOrAbortUndoTransaction();DOPT;
' 3:< Document save history --> :
' 3:< Revit Architecture 2013 2013 (2013.000) : 20120221_2030(x64)
' 3:< Document save history <--
' 3.595058 3:<<ADocument::postLoadDocument
' 20.487211 2:<<MFCDoc::OnOpenDocument [C:\Users\KallocCliff\Desktop\CCCUB_2013.rvt]
' 1:< ::3:: Delta VM: Avail -2 -> 8386044 MB, Used 1242 MB; RAM: Avail +13 -> 11744 MB, Used 1304 MB
'H 10-Jan-2014 19:36:19.933; 1:<
Jrn.Directive "DocSymbol" _
, "[CCCUB_2013.rvt]"
'H 10-Jan-2014 19:36:19.942; 1:<
Jrn.Directive "GlobalToProj" _
, "[CCCUB_2013.rvt]", "Floor Plan: BD_Level 41.60_G/F" _
, 0.00500000000000 _
, 1.00000000000000, 0.00000000000000, -0.00000000000000 _
, -0.00000000000000, 1.00000000000000, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 1.00000000000000 _
, 0.00000000000000, 0.00000000000000, 0.00000000000000
'H 10-Jan-2014 19:36:19.943; 1:<
Jrn.Directive "ProjToPage" _
, 1.00000000000000, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 1.00000000000000, 0.00000000000000 _
Jrn.Directive "WindowSize" _
, 831, 506
' 1:< Before : Create Display Manager
' 1:< RAM Statistics: 11744 / 16075 1304=InUse 1688=Peak
' 1:< VM Statistics: 8386044 / 8388607 1242=InUse 1314=Peak
' 1:< Revit Graphics Information
' 1:< Current Mode : DirectX Hardware
' 1:< Use Hardware: ON
' 1:< Use Overlays : ON
' 1:< After : Create Display Manager
'H 10-Jan-2014 19:36:19.994; 1:<
Jrn.Directive "ScreenResolution" _
, 318, 900
' 1:< Activate "[CCCUB_2013.rvt]" , Floor Plan: BD_Level 41.60_G/F
' 1:< ::3:: Delta VM: Avail -10 -> 8386035 MB, Used +8 -> 1251 MB; RAM: Avail +38 -> 11782 MB, Used +10 -> 1315 MB
' 1:< DBG_INFO: Detected unfrozen change of selection.: line 595 of n:\build\2013_ship_x64_inst_20120221_2030\source\revit\revitui\modscope\ModScope.cpp.
' 2:< ::3:: Delta VM: Avail 8386035 MB, Used 1251 MB; RAM: Avail +15 -> 11798 MB, Used +1 -> 1316 MB
' 2:< DBG_INFO: Newton solver converged in domain but not in range space.: line 332 of Newton.cpp.
' 4:< ::3:: Delta VM: Avail -87 -> 8385949 MB, Used +172 -> 1424 MB, Peak +109 -> 1424 MB; RAM: Avail -103 -> 11695 MB, Used +177 -> 1494 MB
' 1.974713!!! 2:!!!BIG_GAP Open File
' 4:< ::3:: Delta VM: Avail -48 -> 8385901 MB, Used +19 -> 1443 MB, Peak +19 -> 1443 MB; RAM: Avail +0 -> 11696 MB, Used +20 -> 1514 MB
' 0.255802 5:<<<sortByAppearanceSteps
' 5:< DBG_INFO: ExclusionMgr::getGStyleIds(): category -2000122 has no gstyles: line 691 of n:\build\2013_ship_x64_inst_20120221_2030\source\revit\revitdb\view\ExclusionMgrRevit.cpp.
' 5:< DBG_INFO: DBViewPlan::generateViewSpecificGRep() is invoked and returns VC_Invisible - quick rejection failed.: line 5430 of Elem\DBViewPlan.cpp.
' 5:< ::3:: Delta VM: Avail -18 -> 8385883 MB, Used +6 -> 1450 MB, Peak +6 -> 1450 MB; RAM: Avail +12 -> 11708 MB, Used +9 -> 1524 MB
' 5:< Suspicious GNode evaluation like in SPR 196898
' 5:< DBG_INFO: !gRepCutVisitor.hasBeenReallyCut() in FamInstGRepCutVisitor::cutGRep().: line 266 of Elem\FamInstGRepCutVisitor.cpp.
' 5:< ::3:: Delta VM: Avail 8385883 MB, Used +10 -> 1460 MB, Peak +10 -> 1460 MB; RAM: Avail +4 -> 11712 MB, Used +11 -> 1536 MB
' 5:< DBG_INFO: New layer wrapping algorithm failed, reverting to old algorithm: line 5256 of Elem\HostObj.cpp.
' 5:< ::3:: Delta VM: Avail -16 -> 8385867 MB, Used +4 -> 1464 MB, Peak +4 -> 1464 MB; RAM: Avail +30 -> 11743 MB, Used +3 -> 1539 MB
' 5:< DBG_INFO: NULL argument.: line 533 of Elem\RailingHostHelper.cpp.
' 4:< ::3:: Delta VM: Avail -37 -> 8385831 MB, Used +34 -> 1499 MB, Peak +34 -> 1499 MB; RAM: Avail +47 -> 11791 MB, Used +35 -> 1574 MB
' 2.071564 5:<<<updateGReps
' 2.327647 4:<<BD_Level 41.60_G/F: ;PERF;MISC;generating greps
' 4:< DBG_INFO: pFace is a face region of one face in the geometry, but pOwnerFace is not supplied.: line 4571 of Geometry.cpp.
' 4:< DBG_INFO: getShouldOverlapBeVisible failed to find index for layer face: line 1079 of CompoundStructure\HostObjLayerStyles.cpp.
' 4:< ::3:: Delta VM: Avail +28 -> 8385859 MB, Used +9 -> 1508 MB, Peak +9 -> 1508 MB; RAM: Avail +47 -> 11838 MB, Used +9 -> 1584 MB
' 4:< DBG_INFO: Cannot create join finger: line 1819 of CompoundStructure\GeomJoinData.cpp.
' 0.890131 4:<<<;PERF;MISC;tweaking
' 1:< View Open: Element expansion used 4.810098 seconds averaging 0.000073 seconds/hit for 65532 hits.
'C 10-Jan-2014 19:36:25.161; 1:< Protein : Register Preview Factories
'C 10-Jan-2014 19:36:25.161; 1:< Protein : Initialize Renderer Module
'C 10-Jan-2014 19:36:25.161; 1:< Protein : Load the MR Renderer plug-in
' 1:< ::3:: Delta VM: Avail -26 -> 8385833 MB, Used +3 -> 1512 MB, Peak +3 -> 1512 MB; RAM: Avail -6 -> 11832 MB, Used +5 -> 1589 MB
'C 10-Jan-2014 19:36:25.172; 1:< Protein : initialize RPC plug-ins
'C 10-Jan-2014 19:36:25.182; 1:< Protein : Open Protein content Libraries
' 1:< ::3:: Delta VM: Avail -21 -> 8385812 MB, Used +15 -> 1528 MB, Peak +15 -> 1528 MB; RAM: Avail -20 -> 11813 MB, Used +17 -> 1607 MB
'C 10-Jan-2014 19:36:25.248; 1:< Protein : Load Library:
' 1:< C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\2013\assetlibrary_base.adsklib
'C 10-Jan-2014 19:36:25.248; 1:< Protein : Texture Path:
' 1:< C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\
' 1:< ::3:: Delta VM: Avail 8385812 MB, Used +2 -> 1530 MB, Peak +2 -> 1530 MB; RAM: Avail -34 -> 11779 MB, Used +3 -> 1610 MB
'C 10-Jan-2014 19:36:26.542; 1:< Protein : Notify Plugins to load the content on the asset library
'C 10-Jan-2014 19:36:26.542; 1:< Protein : Register the Protein RenderingAsset Manager
'H 10-Jan-2014 19:36:26.544; 1:<
, 1388, 777
'H 10-Jan-2014 19:36:26.551; 1:<
, 1101, 798
, 1388, 777
' 1:< 0 ModelServerState "Created": Current server = "Not Queried", Model server = "", Model server state = "Not Applicable"
' 1:< SLOG $9c5ff523 2014-01-10 19:36:26.718 >WSConfig
' 1.692881!!! 2:!!!BIG_GAP Open File
' 2:< SLOG $9c5ff523 2014-01-10 19:36:26.727 .WSConfig:LockRoot R SCODE=0x80070035
' 1:< initTransactionStatus unable to refresh permissions
' 1:< TaskDialog "The central model \\vmwfs0007\v20\cbes\General\BIM\BIM Admin\References\Reference Project\CCCUB_2011.rvt cannot be found, perhaps due to a lost network connection."
'Id : TaskDialog_Cannot_Find_Central_Model
'CommonButtons : Close
'DefaultButton : Close
' 1:< ::3:: Delta VM: Avail +6 -> 8385818 MB, Used +10 -> 1541 MB, Peak +11 -> 1542 MB; RAM: Avail -18 -> 11762 MB, Used +10 -> 1620 MB
'H 10-Jan-2014 19:36:27.499; 1:<
, 875, 702
'H 10-Jan-2014 19:36:27.500; 1:<
, 1162, 681
'H 10-Jan-2014 19:36:27.552; 1:<
, 154.92134853484256 _
, 154.92134853484256, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 154.92134853484256, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 154.92134853484256 _
'H 10-Jan-2014 19:36:27.553; 1:<
, 879.41962372577291, -653.51011765074554, 0.00000000000000
' 2:< ::3:: Delta VM: Avail -89 -> 8385729 MB, Used +11 -> 1552 MB, Peak +10 -> 1552 MB; RAM: Avail +21 -> 11783 MB, Used +12 -> 1633 MB
' 2:< DBG_INFO: Empty face passed to Face::facet.: line 4755 of Face.cpp.
' 2:< Element with ID = ? cause problems during faceting
' 2:< ::3:: Delta VM: Avail +57 -> 8385786 MB, Used +2 -> 1555 MB, Peak +4 -> 1556 MB; RAM: Avail -5 -> 11779 MB, Used +3 -> 1636 MB
' 2:< ::3:: Delta VM: Avail -8 -> 8385778 MB, Used +10 -> 1565 MB, Peak +9 -> 1565 MB; RAM: Avail -10 -> 11770 MB, Used +4 -> 1640 MB
' 2:< ::3:: Delta VM: Avail -26 -> 8385752 MB, Used +15 -> 1581 MB, Peak +15 -> 1581 MB; RAM: Avail -18 -> 11752 MB, Used +17 -> 1657 MB
' 2:< ::3:: Delta VM: Avail -1 -> 8385751 MB, Used +10 -> 1591 MB, Peak +10 -> 1591 MB; RAM: Avail -11 -> 11741 MB, Used +11 -> 1669 MB
' 1:< ::3:: Delta VM: Avail -59 -> 8385692 MB, Used +61 -> 1653 MB, Peak +61 -> 1653 MB; RAM: Avail -58 -> 11683 MB, Used +55 -> 1724 MB, Peak +36 -> 1724 MB
' 1.402485 2:<<<;PERF;MISC;drawing
' 1:< ::3:: Delta VM: Avail -2 -> 8385691 MB, Used 1653 MB, Peak +2 -> 1656 MB; RAM: Avail +12 -> 11695 MB, Used +7 -> 1732 MB, Peak +8 -> 1732 MB
'H 10-Jan-2014 19:37:27.228; 1:<
Jrn.Data "TaskDialogResult" _
, "The central model \\vmwfs0007\v20\cbes\General\BIM\BIM Admin\References\Reference Project\CCCUB_2011.rvt cannot be found, perhaps due to a lost network connection.", _
"Close", "IDCLOSE"
' 1:< 0 ModelServerState "Destroyed": Current server = "Not Queried", Model server = "", Model server state = "Not Applicable"
' 1:< SLOG $9c5ff523 2014-01-10 19:37:27.238 <WSConfig
' 58.275905!!! 2:!!!BIG_GAP Open File
' 2:< Threaded version of fileExists is enabled. 2.543 seconds elapsed for threaded fileExists \\vmwfs0007\v20\cbes\General\BIM\BIM Admin\References\Reference Project\CCCUB_2011.rvt
' 2.551392 2:<<<fileExists?
' 1:< RAM Statistics: 11695 / 16075 1732=InUse 1733=Peak
' 1:< VM Statistics: 8385691 / 8388607 1653=InUse 1656=Peak
' 1:< 000000001276F8D0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 1:< 000000001276F9D0 CompactMemoryManager Memory Statistics: 256 MB with 2 MB view
' 1:< 000000001276FAD0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 1:< 000000001276FBD0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 1:< 000000001276FCD0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 1:< 000000001276FDD0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 1:< 000000001276FED0 CompactMemoryManager Memory Statistics: 256 MB with 0 MB view
' 1:< 0000000044932D10 CompactMemoryManager Memory Statistics: 256 MB with 2 MB view
' 1:< Element Expansion Statistics:
' 1:< 83% Opening Plans (149645878)
' 1:< 0% Opening RC Plans (0)
' 1:< 0% Opening 3d Views (0)
' 1:< 0% Opening Elevations and Sections (0)
' 1:< 0% In Regnerate (0)
' 1:< 0% In Autojoin (0)
' 1:< 0% In Overlap Checking (0)
' 1:< 2% Reviewing PostedWarnings (2893504)
' 1:< 15% Other (27300246)
' 1:< total bytes expanded: 179944545
' 1:< ;EES;83;0;0;0;0;0;0;2;15;
' 90.546701-- 1:<<Open File/ALL_GAPS 62.887835/TurnOff_GAPs 2%
' 0:< TaskDialog "Revit could not find or read 1 referenced files. What do you want to do?"
'Id : TaskDialog_Unresolved_References
'Command Links:
'1001 : Open Manage Links to correct the problem
'1002 : Ignore and continue opening the project
'DefaultButton : 1001
'H 10-Jan-2014 19:37:31.274; 0:<
, "Revit could not find or read 1 referenced files. What do you want to do?", _
"Ignore and continue opening the project", "1002"
'E 10-Jan-2014 19:37:31.276; 0:<
' [Jrn.File Input Information] COMMON.FILE_INPUT.FILE_TYPE: .rvt 0327286784.000000
'C 10-Jan-2014 19:37:31.684; 0:< idle0_doc
'H 10-Jan-2014 19:37:31.687; 0:<
Jrn.Directive "AllowPressAndDrag" _
, 1
' 0:< <<Begin build CT>>
'Edit mode: IDR_COMMON
'Command: ID_BUTTON_SELECT
'Category: 0
'Bar list:
' Dialog_Essentials_FilterSelectionWs
' Dialog_Essentials_FilterSelectionMm
' Dialog_Essentials_FilterSelectionNew
'Presenter list:
' PP_DebugTab_Binding_Demo
'Product: Architecture
'<<End build CT>>
'E 10-Jan-2014 19:37:31.959; 0:<
Jrn.Size 0 , 875 , 578
'H 10-Jan-2014 19:37:31.959; 0:<
, 875, 578
Jrn.Size 0 , 1162 , 557
, 1162, 557
' 0.128492 1:<<<;PERF;MISC;drawing
' 1:< SLOG $9c5ff523 2014-01-10 19:37:32.105 .LockUsers R rootMIA
'E 10-Jan-2014 19:37:32.246; 0:<
Jrn.Size 0 , 875 , 671
'H 10-Jan-2014 19:37:32.247; 0:<
, 875, 671
'E 10-Jan-2014 19:37:32.247; 0:<
Jrn.Size 0 , 1162 , 650
, 1162, 650
' 0:< ::8:: Delta VM: Avail -14 -> 8385678 MB, Used +9 -> 1662 MB, Peak +9 -> 1665 MB; RAM: Avail -8 -> 11688 MB, Used +9 -> 1741 MB, Peak +8 -> 1741 MB
' 0.113290 1:<<<;PERF;MISC;drawing
'E 10-Jan-2014 19:37:34.043; 0:<
Jrn.Command "Internal" , "Create a default 3D orthographic view. , ID_VIEW_DEFAULT_3DVIEW"
' 3:< ::9:: Delta VM: Avail -989 -> 8384690 MB, Used +1001 -> 2664 MB, Peak +998 -> 2664 MB; RAM: Avail -1011 -> 10678 MB, Used +1002 -> 2743 MB, Peak +1002 -> 2743 MB
' 0.574196 4:<<<sortByAppearanceSteps
' 3:< ::9:: Delta VM: Avail -38 -> 8384652 MB, Used +13 -> 2678 MB, Peak +13 -> 2678 MB; RAM: Avail -14 -> 10664 MB, Used +14 -> 2758 MB, Peak +14 -> 2758 MB
' 1.075102 4:<<<updateGReps
' 1.649536 3:<<???: ;PERF;MISC;generating greps
' 0.690183 3:<<<;PERF;MISC;tweaking
' 0:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBView3d id=16622377: 53856 elements need cache update
' 4:< REGEN_DOC_CONTEXT_INFO: Changing wrong atom in regeneration
' 0.194129 4:<<;PERF;MISC;regenerating
' 0.194203 2:<<EndOrAbortUndoTransaction()--regenNeeded;DOPT;
' 0.154810 2:<<EndOrAbortUndoTransaction()--end of transaction checks;DOPT;
'H 10-Jan-2014 19:37:43.011; 1:<
Jrn.Data "Transaction Successful" _
, "Default 3D View"
' 0.611569 1:<<EndOrAbortUndoTransaction();DOPT;/ALL_GAPS 0.262556/Threshold_GAPs 1%
' 0:< The above Jrn.Command comes from QAT with CommandId [ID_VIEW_DEFAULT_3DVIEW]
'H 10-Jan-2014 19:37:43.045; 0:<
, "[CCCUB_2013.rvt]", "3D View: {3D - KallocCliff}" _
, 0.01000000000000 _
, 0.70710678118655, -0.40824829046386, 0.57735026918963 _
, 0.70710678118655, 0.40824829046386, -0.57735026918963 _
, 0.00000000000000, 0.81649658092773, 0.57735026918963 _
, -202.16938989152820, -351.34197850553790, -468.39355208165227
, 655, 429
' 3:< ::9:: Delta VM: Avail -20 -> 8384632 MB, Used +27 -> 2705 MB, Peak +27 -> 2705 MB; RAM: Avail -28 -> 10636 MB, Used +28 -> 2786 MB, Peak +27 -> 2786 MB
' 0.569035 4:<<<sortByAppearanceSteps
' 3:< ::9:: Delta VM: Avail -13 -> 8384620 MB, Used +0 -> 2706 MB, Peak +0 -> 2706 MB; RAM: Avail -1 -> 10635 MB, Used 2786 MB
' 0.802246 4:<<<updateGReps
' 1.371498 3:<<{3D - KallocCliff}: ;PERF;MISC;generating greps
' 2:< ::9:: Delta VM: Avail +16 -> 8384636 MB, Used 2706 MB; RAM: Avail +0 -> 10636 MB, Used 2786 MB
' 0.693491 3:<<<;PERF;MISC;tweaking
' 0:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBView3d id=16622377: 54549 elements need cache update
'H 10-Jan-2014 19:37:46.564; 0:<
, 45.16084151188034 _
, 45.16084151188034, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 45.16084151188034, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 45.16084151188034 _
, 327.50000000000023, -214.50000000000014, 0.00000000000000
'H 10-Jan-2014 19:37:46.585; 0:<
, 835, 510
'H 10-Jan-2014 19:37:46.586; 0:<
, 1122, 489
'H 10-Jan-2014 19:37:46.588; 0:<
, 871, 667
'H 10-Jan-2014 19:37:46.589; 0:<
, 1162, 650
' 0:< Activate "[CCCUB_2013.rvt]" , 3D View: {3D - KallocCliff}
' 0:< View Open: Element expansion used 0.006897 seconds averaging 0.000011 seconds/hit for 631 hits.
' 0:< View Open: Element expansion used 0.000000 seconds averaging 0.000000 seconds/hit for 0 hits.
'H 10-Jan-2014 19:37:46.786; 0:<
, 68.42551744224298 _
, 68.42551744224298, 0.00000000000000, 0.00000000000000 _
, 0.00000000000000, 68.42551744224298, 0.00000000000000 _
, 0.00000000000000, 0.00000000000000, 68.42551744224298 _
'H 10-Jan-2014 19:37:46.787; 0:<
, 581.00000000000011, -325.00000000000000, 0.00000000000000
' 1:< ::9:: Delta VM: Avail -77 -> 8384560 MB, Used +53 -> 2759 MB, Peak +52 -> 2759 MB; RAM: Avail -54 -> 10582 MB, Used +54 -> 2840 MB, Peak +54 -> 2840 MB
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 18).
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 20).
' 1:< ::9:: Delta VM: Avail -251 -> 8384309 MB, Used +257 -> 3016 MB, Peak +257 -> 3016 MB; RAM: Avail -273 -> 10309 MB, Used +257 -> 3098 MB, Peak +257 -> 3098 MB
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 15).
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 47).
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 45).
' 1:< ::9:: Delta VM: Avail -24 -> 8384286 MB, Used +40 -> 3056 MB, Peak +40 -> 3056 MB; RAM: Avail -51 -> 10258 MB, Used +40 -> 3139 MB, Peak +41 -> 3139 MB
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 17).
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 19).
' 1:< ::9:: Delta VM: Avail -20 -> 8384266 MB, Used +27 -> 3084 MB, Peak +27 -> 3084 MB; RAM: Avail -30 -> 10229 MB, Used +26 -> 3165 MB, Peak +26 -> 3165 MB
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 525).
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 529).
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 549).
' 1:< facetFaceWithSpecifiedAlgorithm is triangulating a long, thin face (face 551).
' 1:< ::9:: Delta VM: Avail -197 -> 8384069 MB, Used +176 -> 3260 MB, Peak +185 -> 3269 MB; RAM: Avail -200 -> 10029 MB, Used +176 -> 3342 MB, Peak +185 -> 3351 MB
' 1:< DBG_INFO: Shewchuk triangulation failed, trying Seidel as a backup.: line 4834 of Face.cpp.
' 1:< ::9:: Delta VM: Avail -34 -> 8384035 MB, Used +21 -> 3281 MB, Peak +12 -> 3281 MB; RAM: Avail -26 -> 10004 MB, Used +20 -> 3363 MB, Peak +11 -> 3363 MB
' 1:< Element with ID = ? cause problems during faceting
' 1:< DBG_INFO: Index into uv array is out of bounds in buildFacets; omitting interpolation.: line 3524 of Face.cpp.
' 0:< ::9:: Delta VM: Avail -8 -> 8384028 MB, Used +22 -> 3304 MB, Peak +22 -> 3304 MB; RAM: Avail -24 -> 9980 MB, Used +22 -> 3386 MB, Peak +22 -> 3386 MB
' 10.819615 1:<<<;PERF;MISC;drawing
'C 10-Jan-2014 19:37:57.977; 0:< idle0_doc
'E 10-Jan-2014 19:38:01.870; 0:<
Jrn.RibbonEvent "Execute external command:CustomCtrl_%CustomCtrl_%Kalloc Fuzor Tech%Kalloc Fuzor Tech Panel%Launch Fuzor:Fuzor.Command"
' 0:< API registering Idling event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< Muted: Jrn.Directive IdleTimeTaskSymbol
' 0:< API registering DocumentClosing event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentClosed event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentChanged event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentSavingAs event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentSavedAs event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentSaving event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
' 0:< API registering DocumentSaved event by application Fuzor (92cc84cd-963f-4d33-8cdc-e01321c04446).
'H 10-Jan-2014 19:38:02.141; 0:<
Jrn.Data "APIStringStringMapJournalData" _
, 0
' 0.102533 1:<<<;PERF;MISC;drawing
' 1:< ::10:: Delta VM: Avail -57 -> 8383972 MB, Used +60 -> 3365 MB, Peak +62 -> 3367 MB; RAM: Avail -76 -> 9904 MB, Used +65 -> 3452 MB, Peak +67 -> 3454 MB
' 1:< DBG_INFO: integrate() achieved an acceptable relative error, but the absolute error is unexpectedly large.: line 230 of Integration.cpp.
'E 10-Jan-2014 19:38:08.266; 1:<
Jrn.MouseMove 0 , 352 , 214
' 1:< ::11:: Delta VM: Avail -621 -> 8383351 MB, Used +662 -> 4027 MB, Peak +659 -> 4027 MB; RAM: Avail -665 -> 9240 MB, Used +648 -> 4100 MB, Peak +645 -> 4100 MB
' 1:< DBG_INFO: Face::computeArea:Inside-out face?: line 5544 of Face.cpp.
' 1:< ::11:: Delta VM: Avail -1224 -> 8382127 MB, Used +1310 -> 5337 MB, Peak +1354 -> 5381 MB; RAM: Avail -1263 -> 7977 MB, Used +1281 -> 5381 MB, Peak +1324 -> 5425 MB
' 0:< ::11:: Delta VM: Avail -289 -> 8381838 MB, Used +174 -> 5512 MB, Peak +131 -> 5512 MB; RAM: Avail -566 -> 7412 MB, Used +173 -> 5555 MB, Peak +129 -> 5555 MB
'E 10-Jan-2014 19:40:13.954; 0:<
' 0:< ::12:: Delta VM: Avail +256 -> 8382094 MB, Used -363 -> 5149 MB; RAM: Avail +363 -> 7775 MB, Used -363 -> 5192 MB
'H 10-Jan-2014 19:40:14.675; 0:<
, 0
'E 10-Jan-2014 19:40:15.106; 0:<
'H 10-Jan-2014 19:40:15.497; 0:<
, 0
' 0:< ::13:: Delta VM: Avail +3 -> 8382098 MB, Used 5149 MB; RAM: Avail -57 -> 7719 MB, Used 5192 MB
' 0.210365 1:<<<;PERF;MISC;drawing
' 0:< ::13:: Delta VM: Avail +2 -> 8382101 MB, Used +23 -> 5172 MB; RAM: Avail -70 -> 7649 MB, Used +23 -> 5215 MB
'E 10-Jan-2014 19:40:19.354; 0:<
Jrn.MouseMove 0 , 18 , 9
Jrn.RibbonEvent "Execute external command:CustomCtrl_%CustomCtrl_%Kalloc Fuzor Tech%Kalloc Fuzor Tech Panel%Clear Scene:Fuzor.NewSceneCommand"
' 0:< ::15:: Delta VM: Avail +358 -> 8382460 MB, Used -1031 -> 4142 MB; RAM: Avail +1055 -> 8705 MB, Used -1046 -> 4170 MB
'H 10-Jan-2014 19:40:19.623; 0:<
, 0
'E 10-Jan-2014 19:40:21.083; 0:<
' 0:< ::16:: Delta VM: Avail +254 -> 8382714 MB, Used -15 -> 4127 MB; RAM: Avail +6 -> 8711 MB, Used -15 -> 4155 MB
'H 10-Jan-2014 19:40:21.292; 0:<
, 0
' 0:< ::16:: Delta VM: Avail 8382714 MB, Used +3 -> 4130 MB; RAM: Avail +16 -> 8727 MB, Used +3 -> 4158 MB
' 0.105322 1:<<<;PERF;MISC;drawing
' 1:< ::16:: Delta VM: Avail -1485 -> 8381230 MB, Used +2117 -> 6247 MB, Peak +735 -> 6247 MB; RAM: Avail -2652 -> 6076 MB, Used +2087 -> 6245 MB, Peak +690 -> 6245 MB
' 1:< ::16:: Delta VM: Avail -16 -> 8381214 MB, Used +25 -> 6272 MB, Peak +25 -> 6272 MB; RAM: Avail -40 -> 6037 MB, Used +25 -> 6271 MB, Peak +25 -> 6271 MB
' 1:< ::16:: Delta VM: Avail -3 -> 8381212 MB, Used +11 -> 6284 MB, Peak +13 -> 6286 MB; RAM: Avail -14 -> 6024 MB, Used +11 -> 6282 MB, Peak +13 -> 6284 MB
' 1:< ::16:: Delta VM: Avail -16 -> 8381196 MB, Used +6 -> 6291 MB, Peak +4 -> 6291 MB; RAM: Avail -12 -> 6012 MB, Used +6 -> 6288 MB, Peak +4 -> 6288 MB
' 1:< ::16:: Delta VM: Avail -215 -> 8380981 MB, Used +262 -> 6553 MB, Peak +262 -> 6553 MB; RAM: Avail -402 -> 5610 MB, Used +258 -> 6547 MB, Peak +258 -> 6547 MB
' 0:< ::16:: Delta VM: Avail -303 -> 8380679 MB, Used +296 -> 6850 MB, Peak +296 -> 6850 MB; RAM: Avail -391 -> 5220 MB, Used +287 -> 6834 MB, Peak +287 -> 6834 MB
'E 10-Jan-2014 19:44:33.711; 0:<
Jrn.MouseMove 1 , 184 , 220
Jrn.LButtonUp 0 , 184 , 220
' 0:< Candidates (curIdx = -1):
' 1:< ::18:: Delta VM: Avail -425 -> 8380254 MB, Used +35 -> 6885 MB, Peak +352 -> 7202 MB; RAM: Avail -607 -> 4614 MB, Used +21 -> 6856 MB, Peak +346 -> 7181 MB
' 1:< Exception occurred
'C 10-Jan-2014 19:46:25.913; 1:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=000007FEFDB9940D
' 1:< RAM Statistics: 4614 / 16075 6856=InUse 7181=Peak
' 1:< VM Statistics: 8380254 / 8388607 6885=InUse 7202=Peak
' 1:< 000000001276F8D0 CompactMemoryManager Memory Statistics: 256 MB with 4 MB view
' 1:< 000000001276F9D0 CompactMemoryManager Memory Statistics: 256 MB with 4 MB view
' 1:< 000000001276FAD0 CompactMemoryManager Memory Statistics: 256 MB with 4 MB view
' 1:< 000000001276FBD0 CompactMemoryManager Memory Statistics: 256 MB with 2 MB view
' 1:< 000000001276FCD0 CompactMemoryManager Memory Statistics: 256 MB with 4 MB view
' 1:< 000000001276FDD0 CompactMemoryManager Memory Statistics: 256 MB with 4 MB view
' 1:< 000000001276FED0 CompactMemoryManager Memory Statistics: 256 MB with 4 MB view
' 1:< 0000000044932D10 CompactMemoryManager Memory Statistics: 256 MB with 4 MB view
' 1:< DBG_INFO: getCompactMemoryStatus examining only one accumulator: line 103 of CompactMemoryManager.cpp.
'E 10-Jan-2014 19:46:25.962; 1:<
Jrn.MouseMove 0 , 191 , 182
' 1:< SLOG $9c5ff523 2014-01-10 19:46:25.962 >Crash
' 1:< SLOG System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 1:< SLOG RAM Statistics: 4612 / 16075 6857=InUse 7181=Peak
' 1:< SLOG VM Statistics: 8380254 / 8388607 6886=InUse 7202=Peak
' 1:< SLOG 000000001276F8D0 CompactMemoryManager Memory Statistics: 256 MB with 4 MB view
' 2:< ::19:: Delta VM: Avail -22 -> 8380233 MB, Used +26 -> 6912 MB; RAM: Avail -80 -> 4534 MB, Used +26 -> 6882 MB
' 2:< Threaded version of fileExists is enabled. 2.559 seconds elapsed for threaded fileExists \\vmwfs0007\v20\cbes\General\BIM\BIM Admin\References\Reference Project\CCCUB_2011.rvt
' 2.551138 2:<<<fileExists?
' 1:< SLOG $9c5ff523 2014-01-10 19:46:28.514 <Crash
' 1:< <<Begin build CT>>
'Edit mode:
'Category: 0
'Bar list:
' Dialog_Revit_DynamicLabelDBar
'Presenter list:
'<<End build CT>>
'E 10-Jan-2014 19:46:28.531; 1:<
Jrn.Size 0 , 659 , 433
'H 10-Jan-2014 19:46:28.531; 1:<
, 659, 433
'E 10-Jan-2014 19:46:28.532; 1:<
Jrn.Size 0 , 946 , 412
'H 10-Jan-2014 19:46:28.532; 1:<
, 946, 412
'E 10-Jan-2014 19:46:28.533; 1:<
'H 10-Jan-2014 19:46:28.533; 1:<
, 875, 671
, 1162, 650
'E 10-Jan-2014 19:46:28.536; 1:<
Jrn.Activate "[CCCUB_2013.rvt]" , "Floor Plan: BD_Level 41.60_G/F"
'Category: 0
'Bar list:
'Presenter list:
'<<End build CT>>
' 1:< CrsTimer event occurred for 0 times in DesktopMFCView [3D View: {3D - KallocCliff}]
' 1:< ::24:: Delta VM: Avail -9 -> 8380225 MB, Used +6 -> 6918 MB; RAM: Avail -11 -> 4523 MB, Used +6 -> 6889 MB
' 1:< DBG_INFO: AfxMessageBox is not converted to Task Dialog.: line 1172 of n:\build\2013_ship_x64_inst_20120221_2030\source\revit\desktopmfc\mfc\DesktopCRS.cpp.
' 1:< MessageBox "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
' 1:< ::24:: Delta VM: Avail +3 -> 8380228 MB, Used -245 -> 6674 MB; RAM: Avail +228 -> 4752 MB, Used -249 -> 6640 MB
' 0.441622 2:<<<;PERF;MISC;drawing
' 1:< ::24:: Delta VM: Avail -64 -> 8380165 MB, Used +148 -> 6822 MB; RAM: Avail -176 -> 4577 MB, Used +146 -> 6787 MB
'E 10-Jan-2014 19:46:39.914; 1:<
Jrn.AddInEvent "AddInJournaling" , "MessageBox(OK,Revit).Click(Cancel)"
'H 10-Jan-2014 19:46:39.952; 1:<
Jrn.Data "MessageBox" _
, "IDOK", "An unrecoverable error has occurred. The program will now be terminated. All of your data has been recently saved, so there is no need to create recovery files."
'C 10-Jan-2014 19:46:39.952; 1:< program terminated
' 1:< ::25:: Delta VM: Avail +12 -> 8380178 MB, Used -2 -> 6820 MB; RAM: Avail +4 -> 4581 MB, Used -6 -> 6782 MB
'C 10-Jan-2014 19:46:39.958; 1:< License cleanup complete: 0, 0, 0
Replies (7)
Message 2 of 8
Hi there, it's hard to tell by just this log. Is it code that works in 2012 and not in 2013? Some thoughts: Did you solved all the obsolete messages visual studio gives? Can't you localize the problem by stepping over the code with break points?
Message 3 of 8
arnostlobel
I am investigating what those particular exceptions actually mean, but it seems that something that was done in the last external command (or commands) – Fuzor.Command and Fuxor.NewSceneCommand might have created geometry that makes Revit to hiccup on it later. Are you familiar with those external command and do you know what do they do to a Revit model? It is not exactly apparent from the journal what exactly had happened but the exceptions you mentioned don’t seem to be the main reason. The actual reason for the crash is a memory access failure, that is trying accessing a piece of data that is not available (anymore) to the application. (E.g. accessing a deleted object.)
Thank you
Arnošt Löbel
Autodesk, Revit R&D
Arnošt Löbel
Message 4 of 8
Hello thanks for the reply.
It's an exception in Revit itself when I switch from a floor plan to 3D view, and the code is of windows library.
Looks like Revit handled the exception internally but I still wonder what's going on in the backend, and if my crash is related to this Revit exception.
Message 5 of 8
arnostlobel
I understand that the exception is thrown from Revit, but it is thrown as a result of making the models’ geometry somehow invalid (at least as triangulation of faces is concerned). I suspect the external commands have something to do with it, thus I am interested in knowing what the commands do to the model. I assume they change the models in some specific way. The fact the change made by the commands is not found invalid immediately upon closing the command’s transaction makes me think that the problems is about some view-specific geometry. Therefore it is still OK to finish the command and stay in the current view. However, when the view changes and Revit needs to (re)create view specific geometry for the now current 3D view, it runs into problems when evaluating the recently made changes.
I wonder if you still experience the crash if you do not run the external commands. Do you? Are those external commands from you application?
Thank you
Arnošt Löbel
Autodesk, Revit R&D
Arnošt Löbel
Message 6 of 8
Thanks for the tips, the Revit exception I caught might not related to my external command, It just happens when I switching between floor plan and 3D view.
In terms of the crash, I don't have any transaction scheduled in my external command ( everything related to Revit is read-only, through constantly raising Revit idle event, and it is accessing view specific geometries ), however I do have unmanaged code on other helping threads which might causing the issue, but I cannot intercept the actual crash point like where the memory is corrupted, is there any indication from the dump like where it goes wrong? Or is it caused by my accessing of those view-specific geometries?
Message 7 of 8
arnostlobel
The “dump” is not a real dump. It is a journal file containing sequence of command and actions happening in a Revit session. For many reasons, API queries are not included there, thus it is not possible for me to tell what any API applications is doing. If you say that you only read, it would mean that your tool should not really be the cause of the problem. On the other hand, do you claim that even without your application installed Revit would still crash when you switch between the views? In other words: does it seem like the issue is with the document itself? Maybe the truth is somewhere in between. The best way to progress is do what I suggested if you haven’t done that yet – uninstall you application and try switching between the views. If that does not crash, then progress to a second step: Install your application, but modify it so it does nothing (by which I mean really nothing – not even subscribing to the Idling event). If that still does not crash, we would then decide what the next step should be.
By the way, I asked to the core-geometry group and was told that there is no easy way to tell why the tessellating algorithm would fail. Apparently, it is a very sophisticated algorithm, but could be finicky sometimes. It may not like certain faces and would not be able to tessellated them, in which case it would throw one of the exceptions you saw. However, the exception should always be handled internally (and I believe it was even in your case) and Revit should have an alternative solution for displaying the naughty face. So, there is definitely something else going on with the model; something that changes the memory data in a bad way. Again, there is no way for me to figure out what that could be just by looking at the Journal. My only conclusion from the journal is that the crash happens almost immediately after two external commands (not idling events) were run. Hence my recommendation for the direction of further investigation.
Thank you
Arnošt Löbel
Autodesk, Revit R&D
Arnošt Löbel
Message 8 of 8
carlos_carmona
I get the same error for just running conduits into a cross junction box that it was modified, changing conduit fitting family individual connector to a face connector and loading this family back into an rvt file. Connecting a conduit into the face that it has been modified crash revit showing the following error on the journal file:
         , "Move Surface Connector"
 'H 22-May-2014 14:44:50.962;   0:<
         , "[Project1]", "Floor Plan: 01.A-Level 1" _
         , 11728.30922645051000 _
         , 11728.30922645051000, 0.00000000000000, 0.00000000000000 _
         , 0.00000000000000, 11728.30922645051000, 0.00000000000000 _
         , 0.00000000000000, 0.00000000000000, 11728.30922645051000 _
         , -8280.87826006747670, -3903.37390037723430, 0.00000000000000
         , -1309.79875968130700, -1433.58463160772160, 0.00000000000000
 ' 1:< ::319:: Delta VM: Avail -18 -> 8386262 MB, Used +1 -> 858 MB; RAM: Avail 7289 MB, Used +1 -> 968 MB
 ' 1:< ;PERF;MISC;MFCDoc::updateAllViews(...,UV_CLEAR_GRAPHIC_CACHE);
 '  0.116030   1:<<UndoMgr::Raising DocumentChanged event
 ' 0:< ;PERF;MISC;MFCDoc::updateAllViews(...,UV_CLEAR_GRAPHIC_CACHE);
 ' 0:< Exception occurred
 'C 22-May-2014 14:44:51.164;   0:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=00000001808C10B8
 ' 0:<   System (MB) [Available /  Total ]  [Revit Memory Usage (MB)   ]
 ' 0:< RAM Statistics:     7289 /    12279       968=InUse     1020=Peak
 ' 0:< VM  Statistics:  8386262 /  8388607       858=InUse      881=Peak
 ' 0:< 000000004B539B80 CompactMemoryManager Memory Statistics: 32 MB with 0 MB view
 ' 0:< 000000004B539C80 CompactMemoryManager Memory Statistics: 32 MB with 0 MB view
 ' 0:< 000000004B538C80 CompactMemoryManager Memory Statistics: 32 MB with 0 MB view
 ' 0:< 000000005C5588E0 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
 ' 0:< 000000005C557EE0 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
 ' 0:< 000000005C5586E0 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
 ' 0:< 000000005C5580E0 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
 ' 0:< 000000005C5578E0 CompactMemoryManager Memory Statistics: 2 MB with 0 MB view
 ' 2:< ;PERF;MISC;FullUpdateGraphicCacheUpdater::updateAll() DBViewProject id=988: 1846 elements need cache update
 ' 0:< DBG_INFO: AfxMessageBox is not converted to Task Dialog.: line 1164 of n:\build\2013_ship_x64_inst_20130531_2115\source\revit\desktopmfc\mfc\DesktopCRS.cpp.
 ' 0:< MessageBox "A fatal error has occurred.  The application will be terminated.  You have the opportunity to save recovery files for all of your changed projects.
 'Would you like to save a recovery file?"
  'E 22-May-2014 14:45:03.070;   0:<
