Revit Energy Analysis
Dear All,
I recently used Revit's simulation for energy consumption of a project.
After I generated the report, there was a couple fields that I did not understood.
I thought that "Life Cycle Electricity Use" field would give me the same value as if I multiplied Electricity EUI by the project's area.
As: Life Cycle Electricity Use = Electricity EUI x area
However, that was not true. Would you kindly explain me why these values are not the same?
Best regards,
Ruben Santos
rosalesduquej
Hi Ruben,
Most likely you will not get an answer from this community
Revit API forum is for API (Application Programming Interface) questions.
For non-API questions, please choose other forums that is more appropriate. For example,
Installation and licensing:
http://forums.autodesk.com/t5/installation-licensing/bd-p/24
Revit Architecture (including common platform product usage questions):
http://forums.autodesk.com/t5/revit-architecture/bd-p/133
Revit Structure:
http://forums.autodesk.com/t5/revit-structure/bd-p/153
Revit MEP:
http://forums.autodesk.com/t5/revit-mep/bd-p/188
Cheers,
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
