Revit does not load correct addin .dll
MGO-Norsyn
MGO-Norsyn
I am working on a modeless add-in implementing an External Event and so couldn't use Add-In Manager to debug.
I had to do a lot of Open Revit -> Load Add-In -> Close Revit and now Revit is stuck on a particular version of the code. I simply cannot get Revit to load latest .dll. I've tried changing addin's GUID, changing path. This could be a VS issue, so I restarted VS and restarted computer. Still no luck, Revit just refuses to load latest .dll.
Anyone has experienced this and can help me overcome this problem?
jeremytammik
In your add-in manifest, you tell Revit exactly which DLL to load.
It cannot load a different one than what you tell it to.
You can either specify the full DLL path or not.
In your situation, I would suggest specifying the full path and adding a breakpoint in the OnStartup method to see what is being loaded.
I would also suggest that you delete all other versions of the DLL from your system, just to make sure.
Details are given in the developer guide:
https://help.autodesk.com/view/RVT/2020/ENU/?guid=Revit_API_Revit_API_Developers_Guide_Introduction_...
Jeremy Tammik
Developer Technical Services
The Building Coder
MGO-Norsyn
I am sorry, the problem was completely unrelated, thank you for answering and sorry for wasting your time.
