Revit does no start
Revit does no start
Revit does no start
Hi everybody,
I am in troubles, and I have no idea what to do. I have been working with Revit during 4 month in my computer, and today I tried to work in it and I cannot start it. It appears the message "The drive or network connection that the shortcut 'Revit 2015.Ink' refers to is unavailable. Make sure that the disk is properly inserted or the network resource is available, and then try again".
I tried to repair and reinstall, and also erase it from my computer and install again, however it is still apear
ing this message.
What I should do?
Thank you so much in advanced.
Can you navigate to "C:\Program Files\Autodesk\Revit 2014\Revit.exe" or similar and launch that to get it running?
Actually I do not find the Revit2015.exe , However I tried to install again the program but when the instalator show up, says that I have already installed the program. I have tried to erase everything from Revit but it still saying the same.
Should I format (sorry, I don't know if this word exist in english, like delete everything from my computer) and try to install again?
I would try uninstalling Revit either through add/remove programs or your install utility first. Then try to reinstall. If you aren't seeing the 2015 Revit.exe then chances are good that got deleted and corrupted your installation.
See this for a complete manual removal of Revit if you can not delete it using add/remove
http://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles/...
