Revit dimension alignment not appeariing consistent
dhananjay_dixit
dhananjay_dixit
Please refer to the image below, we are trying to automate placement of level dimensions after placing the views.
When we add level dimension to the view at the bottom, they do not remain aligned similar to the view on the top and shown in orange box.
Please let me know if I am missing something here.
regards,
Dhananjay
RPTHOMAS108
Probably some code example of what you are doing would help.
Grids have 2D view extent and overall 3D extent, you can extend datum elements such as grids and levels through all parallel views. If you set datum elements to a scope box and then remove that association by deleting the scope box the 2d extents are curtailed to that location. This is trick used in UI but scope box functionality is very limited in API.
